Old 10-12-2005, 02:46 PM   #1
WILDACEX187
WILDACEX187's Avatar
WILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond repute
Send a message via AIM to WILDACEX187
loud pop when parallel parking
im getting a loud pop from the front suspension when im parallel parking, like when i turn to full lock. also when i have the wheel turned to full lock and the front tire touches the curb it makes the same popping sound. i've also heard the same noise when i brake hard in a straight line. i have powertrix t/c rods (the ones with the stupid grease fittings which i hear are not good ), coils, stock tie rods and umm i kinda need an alignment. could this be the bearing going bad in the hub? im lost cause people tell me thats not the sound bad hub bearings make.
SR POWA COUPE LUVVV!!!
WILDACEX187 is offline   Reply With Quote
Old 10-13-2005, 12:35 AM   #2
Indolent
Indolent's Avatar
Indolent has a spectacular aura aboutIndolent has a spectacular aura aboutIndolent has a spectacular aura aboutIndolent has a spectacular aura aboutIndolent has a spectacular aura aboutIndolent has a spectacular aura about
Send a message via AIM to Indolent
my friend had cut springs lol, do you have cut springs? everytime he turned they'd pop or move, but then it's cause the top mounting plate wasn't positioned properly, so when he'd turn, it would get stuck/stopped cause it would hit the chassis, but the spring was still turning along w/the rest of it
Indolent is offline   Reply With Quote
Old 10-13-2005, 12:42 AM   #3
SochBAT
SochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfection
Send a message via AIM to SochBAT
Get an alignment, then try again.
Bad bearings would be more of a grind, than a pop. My guess, off the top of my head, would be your TC rods. Make sure they are TIGHT. Do you have alot of caster? or actually, noticeable caster?
SochBAT is offline   Reply With Quote
Old 10-13-2005, 01:38 AM   #4
WILDACEX187
i have tein coilovers with tein camber plates indolent.
how does caster feel like? i'll make sure my tc rods are on tight tomorrow.
Old 10-13-2005, 06:59 AM   #5
S14DB
AFC #1
S14DB's Avatar
The full lock leads me to believe it's in your steering. Are your rod ends blown?
Old 10-13-2005, 08:58 AM   #6
WILDACEX187
i was thinking my ends also but my friends are like then why does it make the noise when u brake. i have tein ends that i gotta throw on soon. u think thats it s14d?
Old 10-13-2005, 10:31 AM   #7
theicecreamdan
theicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfection
Send a message via AIM to theicecreamdan
it is your TC rod bushings.
Originally Posted by malcolm_x
Be peaceful, be courteous, obey the law, respect everyone; but if someone puts his hand on you, send him to the cemetery.
theicecreamdan is offline   Reply With Quote
Old 10-13-2005, 10:45 AM   #8
xplicit240
xplicit240's Avatar
xplicit240 is just really nicexplicit240 is just really nicexplicit240 is just really nicexplicit240 is just really nicexplicit240 is just really nicexplicit240 is just really nicexplicit240 is just really nicexplicit240 is just really nice
Send a message via AIM to xplicit240
yeh im getting the same problem .. im hearing a clunking noise on the driver side front .. i just found out i lost a stud. i its starting to jerk my wheel .. could it be just that or my tension bushing ends are worn out.. please help im scared.
xplicit240 is offline   Reply With Quote
Old 10-13-2005, 11:40 AM   #9
twitchy
twitchy's Avatar
twitchy is an unknown quantity at this point
i installed polyuerthane TC bushings and it seems to be doing it worse...this popping sound
somethign to think about
Who the hell needs a sig anyhow
twitchy is offline   Reply With Quote
Old 10-13-2005, 02:40 PM   #10
SochBAT
tighten your TC bushing to the TC bracket, and then the forks that go into the LCA. Then tighted the LCA, Macpherson bolts, and tierod end bolt. Then check the rod itself. Make sure NOTHING is loose.
like Dan's butthole.
Oh, caster should be pretty subtle until you really know the feel of your car. I've noticed when i had caster (pass. side wheel was tucked back) my handling wasn't as great at higher speeds.
Old 10-13-2005, 05:34 PM   #11
undercoverdjay
undercoverdjay is making a name for him/her selfundercoverdjay is making a name for him/her self
Send a message via AIM to undercoverdjay
there are 2 bolts that hold your sway bar to your frame. they weill be over the sway bar, tough to see but they are there. check those. check to see if there is any space between the bracket your T/C rods bolt to. Mine was loose, come to find out one was loose and the other is stripped(the frame) so I cant even bolt one side to the frame. i have the SAME popping noise
undercoverdjay is offline   Reply With Quote
Old 10-13-2005, 06:25 PM   #12
p11driver
p11driver's Avatar
p11driver is an unknown quantity at this point
Send a message via AIM to p11driver
I have the same poping sounds also. everyday. making u turns, parking, and especially when breaking.
I have not checked those sway bar bolts, ima try that. but other than that everything is all tight and it still makes the poping sounds.
p11driver is offline   Reply With Quote
Old 10-13-2005, 09:34 PM   #13
WILDACEX187
i have st sway bars. we did them this spring. dont think its that. im leaning more towards my tie rods. didnt get a chance to tighten my tc rod today since its pouring. gonna see how tomorrow is.
Old 10-14-2005, 04:28 PM   #14
gfisch
gfisch's Avatar
gfisch is an unknown quantity at this point
Send a message via AIM to gfisch
I have had the exact same problem with a poppping sound when turning very tight at very low speeds (like in the garage) and also occasionally when stopping very hard.
If anyone locates the problem, please share the solution!
Greg Fischer
[email protected]
'97 240SX SE
'98 Ford Explorer XLT
gfisch is offline   Reply With Quote
Old 10-14-2005, 05:07 PM   #15
SochBAT
actually, i jsut remembered this problem i had. It was the tierods. Tighten em goood. Then get aligned.
Or, you could play it supersafe, and tighten every suspension related bolt on your front end.
Old 10-14-2005, 11:38 PM   #16
p11driver
p11driver's Avatar
I think the problem might be due to the rack and pinion. Once i get a day off work, or free time ill check it out.
Old 10-30-2005, 10:59 PM   #17
WILDACEX187
i noticed also that while im at a stop if i move the steering wheel from one side to the other (wiggle it) i could hear the same pop. wat does that mean?
Old 01-15-2006, 11:57 AM   #18
kawika219
kawika219 is making a name for him/her selfkawika219 is making a name for him/her self
anybody figure this out yet???
kawika219 is offline   Reply With Quote
