08-25-2011, 06:10 PM | #1 |
Need halp!!
sorry guys for the newbness. but i just bough an s13 a little over a month ago in pretty used condition. so i decided to take everything off the car and rebold/mount everything and anything i can. and first thing i decided to do was the sparco sprint seat that it came with. when i unbolted it i found out he jerry-rigged it and put a made-shift bracket to hold the seat in (totally unsafe).
so my question is: is this bracket/base- Sparco 400-Series Driver Seat Base Nissan 240SX S13 89-94 - 400SB026L compatible with the car and the seat? (i have a sparco slider too btw) i did a bit of research but couldnt find much. i also read that the bride brackets are compatible with sparco seats too? i just want to make sure i buy the RIGHT brackets that fit the car (91 s13) thanks in advance! ALSO: if you have a pair used or new and are trying to get rid of them ill be more than happy to purchase them from you (im looking for both passenger and driver side) |
08-26-2011, 02:09 PM | #3 |
if you run the bride bracket you have to modify( welding required ) to make it work. Your best bet is the nagisa or nams rails, they are side mount rails which will let you sit lower and not as high as a bottom mount rail like the sparco ones.
