06-25-2010, 07:27 PM | #1 |
SR20DET: cant get it started need help :(
Okay so i got 89 240sx, ive swapped the old kA24e for an s13 blacktop SR20.
I got an fmic and thats pretty much it for it. So i got it to crank n everything but it wont turn on??? Everytime im done cranking it smells like gas. Whats this mean??? No spark??? New spark plugs??? Plz help guys |
06-25-2010, 07:39 PM | #2 |
see if the ignitor chip is getting power or if its good
“About the time we think we can make ends meet, somebody moves the ends.” ―Herbert Hoover The build http://zilvia.net/f/builds-builds-on...u-city-az.html Owner of NVS Fabrications |
06-25-2010, 07:44 PM | #4 |
YOU need to physically check for Fuel and spark.
Also check the ECU for codes
後輪駆動車1番 1989 Built SR GT2871R -363whp 1998 S14 W/RB25- 250ish (For Now) 1986 SR86 - 200ish 1990 R32 GTR - 320hp Don't Buy Engines from JDM-Online http://zilvia.net/f/businesses/207457-jdm-online.html Don't Buy XS-Power or SSAC Shit |
06-25-2010, 10:21 PM | #9 |
hey im in the same situation with you. if your cranking and its not starting your flooding the cylinder with fuel. i smell gas too when i crank. check for spark. mine was obviously not sparking so i changed it to a new set and it started but it bogged then died cuz my cylinder was flooded with fuel. so take out your spark plugs and check if they spark. if they do just leave out the spark plug and let the fuel evaporate out of the cylinder over night
06-26-2010, 09:14 AM | #16 |
No they dont.
.36 is incorrect. .28 is the correct Gap. You might have a leaky injector. pully off fuel rail with fuel lines attached place on top of a paper bag and turn the Key to "ON" NOT START, so the fuel pump turns on. If fuel comes out then the O-rings need to be replace.
06-26-2010, 02:25 PM | #17 |
Well okay wen i use to crank it the smell from gas wouldnt be on the intake side, but it would be on the exhaust side.
I dont have no downpipe connected at da momment but the turbo elbow with the O2 sensor is connected. And i already took out the spark plugs n im waiting to get sum cash maybe 2moro so i can buy sum spark plugs |
06-28-2010, 08:38 AM | #18 |
So i got the new spark plugs in n i went to get my battery charged n i thought it was cuz it was low charged that my engine cranked slow but it still
does. Bad grounding??? What could be the reason??? |
06-28-2010, 10:06 AM | #19 |
Reading your posts gives me a headache, did you actually check for spark or not? Get a spark plug hook it up to the ignitor, put it againts the head, and crank it.
Nothing says racecar like a stock car with no interior. |
06-28-2010, 10:31 AM | #20 | |
Also... we'd REALLY appreciated it if you took a little more time to reread your posts. It just makes it 10x easier to understand what youre saying. Proper english may be overrated in texts, but here on the forums, we love it. |
06-28-2010, 03:13 PM | #21 |
Yea okay thanks and will do.
i ran into another problem though, my starter gave up already on me, just clicks. Can i still conduct the spark test knowing it wont crank over??? Or is cranking neccesary to see spark??? |
06-28-2010, 03:20 PM | #22 |
You sure your battery just isnt dead?
To test for spark, you can take the CAS out and rotate it manually and check the spark to see if it fires. Either stick an insulated screwdriver in the coil and watch for an arc or see if it arcs with the plug in there. |
06-28-2010, 03:27 PM | #23 |
I just took my battery yesterday to get charged so i highly doubt it that it is the battery.
Im a newb so bare with me lol So i take off the CAS and manually turn it. How do i turn it manually though??? |
06-28-2010, 03:39 PM | #24 |
It spins - take it out and spin the end piece that attaches the exhaust side cam sprocket while the key is in the ignition. It simulates the motor turning and therefor the injectors/spark plugs start firing.
You can test injectors/spark plugs this way. You'll see the rotational end. It takes like 0 effort to turn it... |
06-28-2010, 04:26 PM | #30 |
So i took it out and manually spinned it and i dont see any spark what so ever but i do hear clicks, im not sure if they exactly are comming from the injectors but it sounds like it does???
