11-10-2020, 03:34 PM | #1 |
Key off fuel pressure issue
Getn some insight here....
Sr20det key on get solid fuel pressure about 40psi. Soon as you cycle the key off fuel pressure drops to 0 with in 5-10seconds. Theres no hold of pressure. Running new bosch fuel pumps Tomei fpr new -6an line Top feed injectors and rail System has no leaks at all. Is this typical of sr setups? I cant remeber been sooo long messn with these cars. I know stock cars hold pressure for hours. Any insight guys would be awsome. |
11-10-2020, 04:06 PM | #2 |
If the Tomei fuel pressure regulator is anything like the ball seat Aeromotive ones, they will loose fuel pressure within a few seconds and it's considered normal for that design. I had the same thing happening with my vehicle.
11-10-2020, 04:27 PM | #3 | |
Ahhhh gotcha. I beleve it is like that style |
11-10-2020, 04:31 PM | #5 | |
Okay then yeah, you should be good. Here's a quote from Aeromotive's website:
11-10-2020, 04:45 PM | #7 |
Well, I guess my posts are still being screened by moderators so the post that I had written out earlier probably won't be seen. Do you have a tuned ECU? Are you running dual fuel pumps in the tank? What you can do is use a paperclip to bypass the fuel pump relay and have them continuously running to rule out the pressure drop as the cause. If that works, maybe you could wire in a switch so you could manually bypass the relay whenever needed and you'd essentially have a fuel pump cutoff switch in the even that would want that.
11-10-2020, 04:51 PM | #9 |
Both pumps are ran external. 30amp reays direct feed from battery, using stock relay as a trigger.
When running i hqve 0 fuel pressure issuses....its only first key on/key off start. Worked on numerous cars and seen them all hold fuel pessure key off. Im not 100% sure this is my starting issue im seeking to resolve. But the issue seems tobe resolved after priming the fuel system a few cycles quickly |
11-10-2020, 05:04 PM | #12 |
Yes, most cars will maintain that pressure using a stock pressure regulator. The ball seat style aftermarket regulators seem to bleed off that pressure by design so you may just have to prime it multiple times. Also, depending on the tune, I know the newer turbo Nissan builds need the throttle partially opened in order to start on the first try.
11-10-2020, 06:08 PM | #15 |
im gonna assume that you have a d jetro PFC if your having starting issues, IME its the ecu causing the starting issue.
is the issue with cold starts only? or is it tough to start if you were run into the store for 20 minutes and come back ? |
11-10-2020, 06:10 PM | #16 | |
Its a L-jetro model(maf) As of now just cold start...havent driven it or put long run time... fresh motor |
11-10-2020, 08:07 PM | #20 |
I had a similar issue of not holding pressure after priming. Turned out to be a partially bursted fuel line inside the tank. Maybe you might have a leaking check valve or injector
Sent from my SM-G955U using Tapatalk |
11-11-2020, 08:57 AM | #21 | |
Running all new 6an braided lines and a fuel cell |
11-11-2020, 09:03 AM | #22 |
Can anyone confirm 100% on an sr, aftermarket fuel pressure regulator, key on prime, key off fuel pressure holds steady?
This is annoying the fuck out of me and want to resolve it. Thanks |
11-11-2020, 05:20 PM | #23 |
Small update....
I clamped off the return line AFTER the regulator..pressurized the system, it held no problem at all. So that eliminates the fuel backing feeding thru the pumps. Lookn more n more like its the fpr. Question.... i know the fuel pump comes on for a few seconds during priming. But does the pump stay on durning cranking? Or only once the engine fires up? Idk why this seems so complicated to me..feel like im maken this worse then it needs tobe lol |
11-12-2020, 03:52 PM | #25 |
Resolved for now.... i went ahead and removed the fuel pump relay ground trigger via ecu and just gave it a chassis ground. Now when the key is on, i have constant fuel pump flow, holding rail pressure at 45psi. Car starts right up. Now i gotta replace this 15plus year old starter. Didnt like all those long cranks tryn to start the car.
11-23-2020, 06:37 PM | #26 |
A little late, but my SR with a Fuelab FPR and Bosch 044 build full pressure then falls back to 0 in maybe 10 seconds with key on initial prime. Car always starts 2-3 seconds though no issues.
11-23-2020, 06:58 PM | #27 |
Thanks! I reached out to aeromotive and was told their efi fpr arent designed to hold pressure after key off as it would hinder its performance if it was made todo so.
The remedy ive done so far has worked for now. |
