08-18-2009, 03:05 PM | #1 |
S14 driveshaft question
When swapping from auto to manual, I realize that you have to have a manual s14 driveshaft.
But if the car has ABS, does it have to have the m/t s14 ABS driveshaft or is there only one for ABS and non-ABS? I don't care if I have to disable the ABS system but I really don't think I will be able to find a m/t ABS s14 driveshaft lol If the non-ABS driveshaft fits in the s14, if you somehow disable the ABS I am fine with that. thanks! |
08-18-2009, 03:17 PM | #2 | |
basically the front half is for manual which is fatter and the auto which is skinny. the second half towards the diff is for the abs or non abs. |
08-18-2009, 03:24 PM | #3 |
Oh really I had no idea. So basically I need a S14 manual driveshaft, or can it be S13 manual driveshaft?
So if I can pickup a full driveshaft, I only really need the front half and I can re-use the second half of my auto s14 driveshaft (with ABS)? This will work for SR swap correct? |
08-18-2009, 05:18 PM | #5 |
huh? s13's are 2 piece aswell
08-18-2009, 06:05 PM | #6 | |
also i dont know if the s13 will work but if you get it for cheap you can try. i know you can use a s13 ka tranny on a s14 chasis and use the s14 driveshaft. so i guess you can use the s13 front shaft. again not postive. |
08-19-2009, 02:08 AM | #7 | |
S14 chassis = S14 driveshaft. You cannot use an S13 driveshaft at all.
08-19-2009, 07:21 AM | #9 |
08-19-2009, 08:00 AM | #10 | |
It's always better to keep quiet than to guess and assume.
02-08-2016, 01:06 PM | #12 |
Hate to revive this old thread but I've been searching and this seemed like the closest fit so I'll ask away:
I have a s13 with a s14 rear and using a stock s13 driveshaft. I want to get a one piece steel driveshaft now but on frsport there is a different length between s13\s14 non abs driveshafts. I'd assume a s13 driveshaft will still fit but does anyone have any input before I order this? |
