Old 04-24-2010, 01:21 AM   #1
KeiStarr
KeiStarr is an unknown quantity at this point
Headlight mishap, Need help.
Okay so I messed up admitting you have a problem is the first step, my driver side headlight was out so I disconnected it. I left the positive and negative wires exposed. Needless to say they bumped and caused my passenger headlight to go out. I assumed and hoped it was just a fuse I popped but it was not. Tried testing the relays, they were doing their jobs correctly, and obviously no power was going to the headlight wires now. Maybe there is something I'm not catching or cannot think of that one of you guys might know or can suggest. Any help will be greatly appreciated.
KeiStarr is offline   Reply With Quote
Old 04-24-2010, 01:51 AM   #2
felton local
felton local's Avatar
felton local is an unknown quantity at this point
i literally just had the same problem. everything works normal and fine except my lights dont turn on. i have no power to the fuse's in the passenger side fuse box. i wired a power wire directly to on side of each fuse for the time being. i think i have to unwind the harness going into that box and find the problem wire's. i would like to know if there is a better fix too though. but for ow you can try that.
felton local is offline   Reply With Quote
Old 04-24-2010, 02:02 AM   #3
supreme_1
supreme_1 is on the path to ruinsupreme_1 is on the path to ruinsupreme_1 is on the path to ruin
could you have possibly fried your headlight switch?i coulda sworn the fuse is inbetween tho. if you have a spare try it out.
supreme_1 is offline   Reply With Quote
Old 04-24-2010, 08:16 AM   #4
KeiStarr
I'll have to hit up the junk yard tomorrow then and grab a new switch. Which powers did you tap into for the fuse? Doing this allowed you to continue to use the switch. Hmmm, if thats the case and it does work I didnt fry the switch.
Old 04-24-2010, 08:23 AM   #5
earlysummer84
earlysummer84 is an unknown quantity at this point
here's my suggestion: Bring it to the manufaturer for repairing or maintaining.
Watch A Nightmare on Elm Street Movie Online Free
earlysummer84 is offline   Reply With Quote
