![]() Join Date: Nov 2009
need help with spacers
i just put some front cusco coilovers on my s13 and my tire rubes the spring i have some 18x8.5 rims with 225 tires what size spacers do i need and whats a good brand i just dont want to get them to big or to small please help thank you
what about those adjustable pbm wheel spacers $150.00
Possible sizes with this kit 3,5,7,8,10,12,15,18,20,22,23,25,27,30mm POWERED BY MAX: |
no 10mm should be fine. I'm running a 18x9.5 15 offset in the front and I test fitted a 5mm spacer and had no rubbing issues. Plan to put them on permanently when my longer studs come in. My car isn't slammed though
thanks man , im going to go with the 10mm see how it goes the only thing is my car is low may need to rais it a bit but i like the way 18in rims look when there toucked in a lil bit
![]() Join Date: Jul 2009
Trader Rating: (50)
![]() Feedback Score: 50 reviews
if your running coilovers in the front with aftermarket wheels the offset of 20 or lower is where you want to be.
your wheels are +35 you would need a 15mm spacer to be safe that would make your offset +20 and your good to go. rears doesnt matter. i had xxr 522 17x9+25 and i rubbed on my coilover. hope this helped
wtb s14 roof wing/spoiler! pm me |
Im running 18x9.5 +35 on the front with a 225/40 tire....My rim was rubbing...so I put a 15mm spacer on the front and no problem.....
Now here is the safety factor....I could only get 3 turns on the lugs (unsafe) So I could not find any extended studs (it was sunday). I did find some lugs called Acorn lug nuts....they are tapered and extend into the rim...So I get 8 full turns (Safe). There is a distributor in Riverside...but i got mine from a wheel shop in San bernardino You can see them on ebay....look for Gorilla Lugs.... |
#14 | |
how low
#15 |
I would estimate about a 3 inch drop....but I used a fender roller and rolled my rear fenders aggressively and a mild roll on the front....otherwise yes they would rub.....
My tires are stretched though..... ![]() ![]() ![]() ![]() |
