12-17-2009, 11:46 AM | #1 |
Rear brake line/fitting leaking , please help...
I just finished doing my 300zx brake conversion f&r with ebrake. Everything so far has gone smooth, but where the rear passenger brake line bolts to the caliper is leaking. Calipers just got rebuilt and the rest all seem fine. I have the rear lines tightened down good, but both the lines still swivel around the hardware. I'm thinking maybe the washers are to small, or the hardware isn't screwing down far enough; bad nut or overspray I didn't notice from powdercoating...
Anything like this happen to someone else? Searched with no luck, really don't wanna have to buy new rear conversion lines again. |
12-17-2009, 07:39 PM | #4 |
gdtoday- They threaded in fine, I thought the bolts might be to long or clogged the threads on inside from the coating. leaks right where the lines bolt to the rear caliper.
brian3676- I bought the lines like 6-9 month ago and cant quite remember, I wanna so circuit sports, or project silvia... Both sound about right lol. |
12-17-2009, 09:08 PM | #6 |
so your using Banjo Bolts???
the 300ZX use flaired fittings not banjo bolts
後輪駆動車1番 1989 Built SR GT2871R -363whp 1998 S14 W/RB25- 250ish (For Now) 1986 SR86 - 200ish 1990 R32 GTR - 320hp Don't Buy Engines from JDM-Online http://zilvia.net/f/businesses/207457-jdm-online.html Don't Buy XS-Power or SSAC Shit |
12-18-2009, 01:44 PM | #7 |
No didn't use any Teflon tape, that might be my quick fix but still kinda worried on longevity. Yeah I didn't torque them very hard, just wrenched tight and left them like that, I've had a bad experience once with aluminum and cross-threading.... not fun.. wont be doing that anytime soon.lol
Sileighty- yeah the fronts are flared fittings but the rears have banjo bolts. Or at least that's the way these conversion lines came. I'm thinking I'll just go pull the passenger rear bolt and washers off and head down to the local auto store and see if they have new 300zx bolts, or even shorter ones. I'll didn't tighten the rears very tight, but the rear washers might be no good for any further use, I thought about stacking two washers on the bottom instead of one, but don't really think that'll be the best decision. |
12-18-2009, 09:56 PM | #8 |
the rears are also flared fittings, you must have been sent a set of lines for the stock calipers,
12-20-2009, 03:59 PM | #9 |
damn I guess there's no way around it, I received the wrong rears and gotta buy another set. At least I wont worry about leaks, I also kinda thought there wasn't much cable length either for the rears, seams like to much suspension movement and the cable would be taunt.
thanks for the help Sileighty |
