Old 08-08-2014, 05:01 PM   #1
Lej
Lej is an unknown quantity at this point
Rb20det revs fine, all the way up to the limiter, but when in gear, it will stall
It will drive fine for about 5 seconds, (enough to get out of the drive way) then it stalls.. Any ideas? This was a rb20det I swapped into an s13.. It builds boost and all while sittig in neutral, or with the clutch in.. But as soon as torque is applied, it stalls.
Lej is offline   Reply With Quote
Old 08-09-2014, 02:43 PM   #2
MilkMan1218
MilkMan1218 is an unknown quantity at this point
Anybody got any ideas?
MilkMan1218 is offline   Reply With Quote
Old 08-12-2014, 08:40 PM   #3
curo72
curo72 is an unknown quantity at this point
I'd check your fuel filter. Similar thing happened to a car my Dad had years ago. Revved in idle fine, but wouldn't go over 60km/h, and would jerk and buck if you tried.
If not, check out the rest of the fuel supply.
curo72 is offline   Reply With Quote
Old 08-13-2014, 07:17 PM   #4
Lej
Fuel is good, I put the pump in a bucket of a gasoline and it's doing a full loop fine. Dropping straight back into the tank.
Old 08-13-2014, 07:40 PM   #5
Ilya
Ilya's Avatar
Ilya is an unknown quantity at this point
If it revs fine in neutral, why would you even try to rev it in gear with the clutch pressed in? Just trying to figure out your reasoning to see if we should even proceed...
Torque = load
The ecu computes timing, injector pulse, injector pulse length etc. depending on the load.
Ecu uses the following sensors to determine load:
-MAF
-TPS
-oxygen sensor
-coolant temp sensor(maybe not)
-knock sensor(maybe not)
- x-sensor where x is any other sensor I missed
Now, what do you think happens when one of those sensors is not functioning correctly?
Ilya is offline   Reply With Quote
Old 08-13-2014, 07:52 PM   #6
Lej
Why does it matter if I revved it with the clutched pressed it? I'm just explaining how without a load, it acts normal.. MAF and TPS are good, not sure how to check o2 or knock or coolant. No codes on ecu.
Old 08-13-2014, 10:38 PM   #7
Lej
update: ok opened up the breather that we originally had blocked off.. car now runs fine with people in, but after it heats up it begins to blow smoke and lag extremely bad. starting to think it's a blown head gasket. here's a video
http://www.youtube.com/watch?v=UhLvzNeLLKU
