Old 07-18-2023, 06:42 PM   #1
Solus Christus
Solus Christus's Avatar
Solus Christus is an unknown quantity at this point
Exclamation Intercooler options for less bumper cutting
Hello, I have a stock 94 180SX. I am currently interested in simply doing air intake, turbo back exhaust, and a better intercooler setup. I don't currently plan to try to get tons of power.
My concern though is I don't want to remove too much of the stock look of the car. Any suggestions for a FMIC (or beefier SMIC) that will accomplish little to no bumper cutting?
Thanks!
Solus Christus is offline   Reply With Quote
Old 07-18-2023, 09:02 PM   #2
cured13
cured13 has a spectacular aura aboutcured13 has a spectacular aura aboutcured13 has a spectacular aura aboutcured13 has a spectacular aura aboutcured13 has a spectacular aura aboutcured13 has a spectacular aura aboutcured13 has a spectacular aura about
ARC sidemount
cured13 is offline   Reply With Quote
Old 07-19-2023, 05:54 AM   #3
tuzzio
tuzzio's Avatar
ARC SMIC, or PBM Highmount
Old 07-19-2023, 06:18 AM   #4
Solus Christus
Originally Posted by cured13 View Post
ARC sidemount
They are all used on ebay or do they make them new still?
Old 07-19-2023, 11:17 AM   #5
anti tyler
GM2 (SW/AW)
anti tyler's Avatar
Trader Rating: (37)
anti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfection
Feedback Score: 37 reviews
Send a message via AIM to anti tyler Send a message via Yahoo to anti tyler
Don't be afraid of used stuff. just leak test it and return it if it leaks
WillEastS14:
mannn u whylin son.
but that shyt has SWAG
KA-T for life!
Current for sale advertisement
anti tyler is offline   Reply With Quote
Old 07-19-2023, 11:49 AM   #6
silviaks2nr
silviaks2nr's Avatar
I built a backdoor style intercooler for my s14 with a 4" core if you look on my build thread you can find some photos. It requires that you use a narrower radiator and minor trimming to the core support (down low where you don't even see it)
'98 240sx 5spd
kouki 2jz t56 swap build
Old 07-19-2023, 02:22 PM   #7
AKADriver
AKADriver's Avatar
S15 OEM sidemount is bigger than the RPS13 one and when they pop up on Yahoo Japan or UP Garage/croober they're usually dirt cheap. Swap over the piping and brackets and it bolts on, slight trimming to the duct to accommodate the added inch or so of core thickness.
Old 07-19-2023, 02:39 PM   #8
AKADriver
AKADriver's Avatar
"Backdoor" and PBM Highmount style intercoolers don't fit a 180SX, the charge pipes pass through where the popup headlight motors go.
Old 07-19-2023, 02:50 PM   #9
silviaks2nr
maybe any off the shelf ones (which are not rated for high HP anyways). My design would fit pop ups no problem
'98 240sx 5spd
Old 07-19-2023, 02:58 PM   #10
Solus Christus
I think this is what I'll do: source an S15 SMIC and swap over pipes and inlets. I wonder since th S15 is still so much newer than an S13, I might be able to buy brand new from Japan parts if I can't find used.
Thanks!
Old 07-19-2023, 03:17 PM   #11
AKADriver
AKADriver's Avatar
It might work, but it'd be extremely tight and would probably require fabbing new brackets, the stock brackets aren't fitting with that.
OP is looking for a low impact/bolt on solution for a low power car.
Old 07-19-2023, 03:24 PM   #12
Solus Christus
Thanks!
Scratch that! $1500 new for OEM S15 SMIC. YIKES. Checking ebay.
Old 07-19-2023, 09:12 PM   #13
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
Feedback Score: 73 reviews
What is the reason you're looking for an upgrade?
Old 07-20-2023, 07:40 AM   #14
feito
feito's Avatar
feito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymore
regular front mount with charge pipes painted black? All you have to do is trim the bumper cover and cut two circular holes on the chassis for the charge pipes.
even ka-t guys can pull a stock look with painted pipes. Looks way cleaner imo too.
stolen from the sleeper ka-t thread:
Tuners are big bullies
feito is offline   Reply With Quote
Old 07-20-2023, 07:44 AM   #15
AKADriver
AKADriver's Avatar
Like I said check croooober and Y!AJ
Here's one for 550 yen (four US dollars):
https://www.croooober.com/en/item/cp...ler-Silvia-S15
Probably get better shipping rates from buyee or other yahoo auctions shipping service though:
https://buyee.jp/item/search/query/s...nslationType=1
Old 07-20-2023, 08:50 AM   #16
Solus Christus
The bummer is every one of them I have clicked on so far don't do international shipping. Thanks for heads up though, I'll keep checking!
**Edit that's at least what Buyee is warning me about.
Old 07-20-2023, 08:52 AM   #17
Solus Christus
I was under the impression the limitations of the S15 SMIC are higher than the S13 SMIC and therefore could handle more like 11-12 psi of boost.
Old 07-20-2023, 09:20 AM   #18
AKADriver
AKADriver's Avatar
Buyee is a shipping relay. The seller ships to Buyee's warehouse in Japan, and Buyee forwards it to the US. So from the seller's POV it's a local shipment.
The only thing is sometimes you have to fight with Buyee to get them to realize that an intercooler or whatever isn't a HAZMAT and let you buy it. They'll flag listings because of some random keyword and block you from bidding.
Old 07-20-2023, 09:23 AM   #19
Solus Christus
Thanks!! I just petitioned them on two listings.
Old 07-22-2023, 04:04 PM   #20
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
The limitations for a side mount are more around cooling the charge temps and heatsoak than anything
