Old 02-01-2017, 02:24 PM   #1
gaz_moose
gaz_moose is an unknown quantity at this point
SR20 from 8:5:1 to 9:1 compression
Ive changed from stock compression ratio to roughly 9:1, am I going to be ok using the car on the current map that I had done for the old compression ratio? I want to put some miles on it before I stick a bigger turbo on it and go all out on the rollers. I don't plan on bashing it off the limiter just cruising it around on the 100RON fuel its mapped for..
its a VVT s14 engine mapped on nistune with s15 injectors and turbo/z32afm,
it had decent (140psi) compression test results when mapped and should have 150/160 across the board now as its brand spanking new.
soo. id going up half a point on CR a real deal breaker??
gaz_moose is offline   Reply With Quote
Old 02-01-2017, 05:58 PM   #2
hanzbrady
hanzbrady's Avatar
hanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura about
You could be fine, you could melt a piston.
Or, you could tune the car and know it's safe.
[email protected]
hanzbrady is offline   Reply With Quote
Old 02-02-2017, 07:40 AM   #3
gaz_moose
money..it all boils down to money.
tune the car on current setup cost money..which could go towards eventual goals..
buy new turbo cost money..
retune to suit new turbo even more money..
Old 02-02-2017, 07:41 AM   #4
hanzbrady
hanzbrady's Avatar
Rebuilding engines cost more money.
[email protected]
Old 02-02-2017, 07:57 AM   #5
TheRealSy90
TheRealSy90's Avatar
150/160 with 9:1 pistons? My stock unopened s13 sr will do 180 on a compression tester on all four cylinders lol.
Such a good signature.
Old 02-02-2017, 08:06 AM   #6
RalliartRsX
Trader Rating: (32)
RalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfection
Feedback Score: 32 reviews
Standard compression for a SR20DET @ 8.5:1 compression ratio according to the FSM is 156..........
RalliartRsX is offline   Reply With Quote
Old 02-02-2017, 08:51 AM   #7
mewantkouki
Trader Rating: (36)
mewantkouki will become famous soon enoughmewantkouki will become famous soon enoughmewantkouki will become famous soon enough
Feedback Score: 36 reviews
Your stock unopened SR has carbon build up on the tops of the pistons. That's why you're getting 180psi.
mewantkouki is offline   Reply With Quote
Old 02-02-2017, 10:31 AM   #8
TheRealSy90
Good, cause it runs like a raped ape.
Old 02-02-2017, 02:39 PM   #9
gaz_moose
that's why I got no money left. the simple rebuild became out of control.
guess I will just take my chances!!
Old 02-02-2017, 05:32 PM   #10
Kingtal0n
Kingtal0n's Avatar
I've never tested a used sr20det and come up with more than 130~psi. They all ran fine, great even.
from 8.5 to 9:1 compression is so slight, you won't notice, the computer wont notice, nobody is going to notice. If you think about it in reverse, at 130psi the original 8.5:1 OEM compression is probably down a notch, and it still runs fine. So up a notch, down a notch, same difference.
Old 02-02-2017, 07:56 PM   #11
TheRealSy90
Idk, tested mine with throttle body open and 180 on all four.
Old 02-03-2017, 04:26 AM   #12
gaz_moose
@therealsy90... I wonder if you have NA pistons or something.
@kingtal0n... that was where my thoughts lay. ive seen sr20's that still run with 110psi, they were gutless but still ran non the less.
Old 02-07-2017, 02:23 PM   #13
pacotaco345
pacotaco345's Avatar
pacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond repute
I just pulled my motor out that had 110 psi and that thing SCREAMED. I just wasn't comfortable with those numbers. Are you on 91 or 93? I'd be kinda wary running 9:1 on 91 octane.. but just don't go driving uphill in hot weather at low rpm and you should be fine.
pacotaco345 is offline   Reply With Quote
Old 02-07-2017, 02:30 PM   #14
RalliartRsX
Trader Rating: (32)
9:1 on 91 octane is nary an issue.........especially with the tuning solutions we have. Many new turbo vehicles (non direct injection) run 9:1 and up on 91 octane
Commifornia max octane rating is 91, less we forget (which I see SoCal in your location, so you should be well aware lol)
Old 02-07-2017, 02:36 PM   #15
S14kouki805
S14kouki805 has much to be proud ofS14kouki805 has much to be proud ofS14kouki805 has much to be proud ofS14kouki805 has much to be proud ofS14kouki805 has much to be proud ofS14kouki805 has much to be proud ofS14kouki805 has much to be proud ofS14kouki805 has much to be proud ofS14kouki805 has much to be proud ofS14kouki805 has much to be proud ofS14kouki805 has much to be proud of
Excuse my ignorance but are you SUPPOSED to do a compression check with the throttle open?
S14kouki805 is offline   Reply With Quote
Old 02-07-2017, 02:40 PM   #16
pacotaco345
I just re-read OP's post, he's on 100 RON which is like our 93.. But if the car was tuned for his old setup on 100 RON then that's where the issue lies.
OP I'd ask your tuner how balls to the wall he went on the last map, if he left some on the table you should be fine, but if he was on the edge of knock trying to squeeze every last hp out of the car then you might have an issue.
Old 02-07-2017, 02:41 PM   #17
pacotaco345
yes messagelength
Old 02-08-2017, 04:32 AM   #18
gaz_moose
wait how can you guys have 93 that is 100ron? surely it is 93ron?? man your country is crazy.
tbh it was originally tuned about 8 years ago so my tuner wouldn't remember a damn thing about it. im only going to cruise it around not go balls to the wall so I think I should be fairly safe if I put fresh fuel in the tank when I use it.
Old 02-08-2017, 04:36 AM   #19
RalliartRsX
Trader Rating: (32)
RON - Europe/UK (anywhere outside the US) octane unit
Octane - US octane unit
