Old 01-09-2003, 08:40 PM   #1
madwilly240
madwilly240 is an unknown quantity at this point
s14 taking out guage cluster in s14... i searched
I just got reverse indiglos from procarparts and i took apart the steering column, but I dont wanna pull too hard on the black plastic part without asking you guys. i took out the 2 screws above the guages, and then i started to pull on the cruise control panel, dimmer panel. it wasnt popping off too easily, and its obviously all one piece, but I dont know what to do. thanks in advance.
madwilly240 is offline   Reply With Quote
Old 01-09-2003, 09:10 PM   #2
xS1LV1Ax
xS1LV1Ax's Avatar
xS1LV1Ax is an unknown quantity at this point
Send a message via AIM to xS1LV1Ax Send a message via MSN to xS1LV1Ax
I just put my Silver Reverse Indiglos from ProCarParts in.....
To pull out that big piece, pull the steering wheel all the way down and pull on the piece from the bottom.... From there its hould pop off and u can "bojangle" it out....the dimmer switch and the cruise control dont pop out real easy, but they do pop out. Try wiggling (sp?) them.... Once that is out, there will be 1 screw on the top of the cluster and 2 on bottom. Afterthat, it is all unplugging from the back of the cluster and u are ready to go......
For some more help with placeing the gauges over the needles and long dials (clock set and tripometer reset) search for a thread by aceinthehole about indiglo install.....it really helped me....GOOD LUCK!
PJ
xS1LV1Ax is offline   Reply With Quote
