Old 09-04-2022, 01:03 PM   #1
CrimsonRockett
The Architect.
CrimsonRockett's Avatar
Trader Rating: (392)
Feedback Score: 392 reviews
Arrow Massive S14 Zenki / Kouki Garage Sale - Interior, Exterior, Suspension, Wiring, +more
SHIPPING: At buyers expense
CONTACT INFORMATION - [email protected] or via PM.
PAYMENT OPTIONS: Cash, Paypal
Combining all of my S14 items into one thread to keep things simple.
S14
Exterior
$15 - S14 Zenki/Kouki Turn Signal Housing (lens damaged, LH and RH available)
$30 - S14 Zenki/Kouki RH Turn Signal
$40 - S14 License Plate Light
$75 - S14 Windshield Wiper Cowl Cover
$250 - S14 Wingless Trunk
$200 - S14 Zenki LH Fender (Mint)
$50 - S14 Zenki RH Fender (Dented, but easy repair)
$150 - S14 LH Rocker Panel (cut where it meets the quarter panel
$250 - S14 Subframe Mounting Studs
$25 - S14 Zenki OEM Bumper (trimmed for large FMIC)
$200 - S14 Zenki OEM Bumper Support with retainer
$50 - S14 Rear Bumper Support (two available)
$15 - S14 Rear Bumper Brackets
$25 - S14 Rear Factory Tow Hook
$75 - S14 RH A-Pillar Exterior Trim
$50 - S14 RH Quarter Glass (no trim)
$10 - S14 LH or RH Weatherstripping Retainer
$75 - S14 LH Door Window
$75 - S14 RH Door Window
$40 - S14 Rear Glass Lower Finisher Trim
$25 - S14 Kouki RH Door Handle
$25 - S14 Zenki Hood Prop
$50 - S14 Wiper Linkage Arm Set
$20 - S14 Windshield Wiper Cowl Metal Cover
$30 - S14 Fuel lid door (two available)
$50 - S14 SE Trunk Support Bars
Interior
$20 - S14 Dome Light
$15 - S14 Antenna wiring harness
$100 - S14 Fuel lid release cable with brackets (fuel lid only, no trunk release on this model)
$15 - S14 LH or RH Door Handle Bezel
$50 - S14 Rear View Mirror
$50 - S14 Cluster Bezel
$15 - S14 Throttle Pedal Stopper
$25 - S14 Turn Signal/Wiper Stalk Holder / Bracket
$40 - S14 Wiper Stalk
$35 - S14 RH Kick Panel
$100 - S14 Heater Core Box (removed from a '95 Zenki)
$30 - S14 Speaker Door Bracket Set
$15 - S14 RH Door Speaker Bracket
$15 - S14 RH or LH Triangle mirror cover
$30 - S14 LH/RH Triangle mirror cover set
$20 - S14 Lower Dash / Steering Column bracket (three available)
$15 - Steering wheel spacer
$10 - black spin knob
$30 - S14 RH A-Pillar
$75 - S14 B/C Pillar Set
$15 - S14 Rear Seat Airbag Module Cover (prevents middle section on seat from sagging)
$25 - S14 Rear Seat Striker Bracket
$30 - S14 Fuel Pump Sender Cover
Suspension/Brakes
$100 - S14 Rear Knuckles
$30 - S14 Rear Subframe Braces
$100 - S14 Brake/Fuel Hard lines (NON ABS)
$100 - S14 Brake/Fuel Hard lines (ABS)
$400 - S14 GP Sports Coilovers (1 Front has a bent shaft. Straighten it out and run it on a cheap drift car)
$60 - S14 Rear Lower support bar
$40 - S14 Blue Subframe Collars
$20 - S14 Driveshaft tunnel brace
Engine/Drivetrain/Fuel
$60 - S14 Fuel Tank Straps
$250 - S14 Chasebays Power Steering Reservoir/Lines Set
$60 - S14 Cruise Control assembly
$50 - S14 Fuel Filler Neck
$10 - S14 Fuel Filler Neck Hose
$30 - S14 Power Steering Cooling Hard lines
$40 - S14 ABS Pump Assembly (95 Zenki)
$30 - S14 Rear Exhaust Heat Shield (bolts on above muffler)
$25 - S14 Center Exhaust Heat Shield (bolts on above catalytic converter)
Exterior
$150 - S14 LH Rocker Panel (cut where it meets the quarter panel)
$50 - S14 Rear Bumper Support (three available)
Interior
-Jspec-
Instagram/CrimsonRockett
Old 09-04-2022, 01:04 PM   #2
CrimsonRockett
The Architect.
$15 - S14 RH Triangle mirror cover
Suspension/Brakes
$50 - S14 Blue Subframe Collars
-Jspec-
Old 09-04-2022, 01:04 PM   #3
CrimsonRockett
The Architect.
$100 - S14 EVAP Box Assembly ('97 Kouki)
-Jspec-
Old 09-26-2022, 01:48 PM   #4
CrimsonRockett
The Architect.
Updated post. Adding significantly more parts this week.
-Jspec-
Old 09-27-2022, 12:46 PM   #5
bmar19
bmar19 is an unknown quantity at this point
Pm?d you, If it didn?t go through please let me know
bmar19 is offline   Reply With Quote
Old 10-06-2022, 09:27 PM   #6
nachos14
nachos14's Avatar
nachos14 is an unknown quantity at this point
Hi Crimson, nice list.
Any a/c components? Cant find a damn condenser for my s14 zenki ��
nachos14 is offline   Reply With Quote
Old 10-08-2022, 02:19 PM   #7
CrimsonRockett
The Architect.
Listing updated. Adding significantly more parts over the next few days.
-Jspec-
Old 10-20-2022, 11:29 AM   #8
seto_s14
seto_s14's Avatar
seto_s14 has much to be proud ofseto_s14 has much to be proud ofseto_s14 has much to be proud ofseto_s14 has much to be proud ofseto_s14 has much to be proud ofseto_s14 has much to be proud ofseto_s14 has much to be proud ofseto_s14 has much to be proud ofseto_s14 has much to be proud ofseto_s14 has much to be proud ofseto_s14 has much to be proud of
Send a message via AIM to seto_s14
i'm down to meetup for the tow hook
San Gabriel Car Detailing
https://www.ocdshine.com
seto_s14 is offline   Reply With Quote
Old 11-08-2022, 04:24 PM   #9
CrimsonRockett
The Architect.
Updated the main posts.
Adding more parts this week.
-Jspec-
