Old 07-14-2014, 10:52 AM   #1
PedroJG
PedroJG is an unknown quantity at this point
My KA won't stay on, please help!!
Hopefully i'm posting this in the right section but I need some serious help with my s13. Here's the story, a couple months ago I was driving my car and all of a sudden the car started to sputter. The first time it did i just pressed the gas and it was all ok. Then it did a second time while driving to school one morning and completely stalled on me and every time i turn on the car ill be able to drive for about 2min and it'll just stall again. I took it to a mechanic and he checked the fuel pressure and said that it would continuously decrease with that being said he changed the fuel pump. I then drove it home and everything was fine then the next day it did it again. I had it towed home and decided to work on it my self. (great idea right?) well i cleaned up all the emission, egr valve delete, vacuum lines. etc. After everything was cleaned up I put it all back together and now when i start the car it idles around 500rpm and sounds horrible (could just be my ugly ass exhaust that previous owner put in). I've checked timing maybe 20 times already. The engine shakes a bunch and when i try to press the gas it stalls right away. If i just let it idle it'll just shake horrendously and then eventually stall. If anyone can help me diagnosis this problem or fix it please let me know, I've been stuck without a car for 2 months and classes start back up in august!!
List of parts changed/upgraded:
Fuel pump
Fuel filter
Egr block off plate
Deleted all the emissions (yes alllllll of it)
Isis radiator with electric fans and shroud
Spark plugs/wires, distributor, etc.
Coolant temp sensor
New Harness and ECU
PedroJG is offline   Reply With Quote
Old 07-14-2014, 04:05 PM   #2
RickyS13.
RickyS13.'s Avatar
RickyS13. is an unknown quantity at this point
Check/swap your fuel injectors. Even with one missing the engine will run like absolute shit and shake tremenously. Unplug the fuel injector clips and watch for any changes in engine stability. I unplugged injector #3 on mine and it did nothing so I knew it was that injector that had gone bad.
RickyS13. is offline   Reply With Quote
Old 07-14-2014, 04:14 PM   #3
PedroJG
That's what I did today, every time i unplugged the injector from the harness the car will almost stall. I tried this with every injector, i'm not sure if that's a valid test to rule out the injectors though. I also checked them with a multimeter and got 11 ohms across.
Old 07-14-2014, 06:15 PM   #4
Mishkin_707
Mishkin_707's Avatar
Mishkin_707 is an unknown quantity at this point
Does it smell like a shit load of fuel? My car s13 did this once, threw a whole bunch of parts at it (years ago) just to find out my coolant temp sensor was bad making the ecu think the car was cold and just dumping fuel into the engine til it flooded itself,
Mishkin_707 is offline   Reply With Quote
Old 07-14-2014, 06:16 PM   #5
Mishkin_707
Disconnect the two pin connector and run the car, the single pin connector it just for the gauge
Old 07-14-2014, 06:22 PM   #6
PedroJG
It does smell like fuel, but I bought a brand new coolant temp sensor from autozone maybe a week ago. Sorry I forgot to list it as one of the changed parts!
Old 07-14-2014, 07:02 PM   #7
93_ProjectS13
93_ProjectS13's Avatar
93_ProjectS13 is on a distinguished road
Turn the choke off..
93_ProjectS13 is offline   Reply With Quote
Old 07-14-2014, 07:16 PM   #8
PedroJG
Can you elaborate on that?
Old 07-14-2014, 10:00 PM   #9
Bushido
Bushido's Avatar
checked your injector o rings?
Old 07-14-2014, 10:17 PM   #10
PedroJG
Will be pulling out the injectors tomorrow, along with checking the TPS, because since i deleted all my emissions, i had to adjust my throttle plate but never adjusted the TPS oops I'll keep everyone updated!
Old 07-15-2014, 01:32 AM   #11
Zzz89
Zzz89 is an unknown quantity at this point
Check ecu codes, spray MAF with CRC MAF cleaner as well. A dirty MAF caused all sorts of idling problems for me and it was a really simple fix.
Zzz89 is offline   Reply With Quote
Old 07-15-2014, 10:46 AM   #12
PedroJG
Update: I couldn't check the TPS because i didn't have alligator clips (theirs a video on youtube on how to check the TPS). But while the car was idling (horribly) I pulled off the connector for the TPS and it almost stalled on me, I dont really know if thats a valid test but yea... I pulled out my fuel rail and found some kind of cotton material on the 3rd injector, could've just been when i put the fuel rail back on a couple weeks ago and didn't notice it, I started the car and let it idle and tried to press the gas but nothing happens the car just idles really low like at 300rpm and then doesn't move no matter how much i press the pedal. I changed out the MAF but nothing happens, it didn't change anything.
Old 07-17-2014, 11:11 AM   #13
kennedy8383
kennedy8383's Avatar
kennedy8383 is an unknown quantity at this point
Maybe the car not getting enough gas.. have check the fuel filter..
kennedy8383 is offline   Reply With Quote
Old 07-17-2014, 12:18 PM   #14
PedroJG
Update: I disconnected my fuel rail and connected a clear bottle to the fuel filter side of the hose so i could see if my fuel was dirty and when i primed it no fuel came out? and when i cranked it no fuel came out? So does this mean i have a bad fuel pump? because I changed the fuel pump a month ago. Also I have a question about the emission delete that i did. In this picture i drew the hoses that are connected. #1 is a water hose going from the back of the block to the thermostat. #2 is the pcv valve going into the pcv system? #3 is just loop from the intake to the thermostat housing. Is there anything i need to fix with this setup or add? Did i do this right or is there a better way?
[IMG][/IMG]
Old 07-17-2014, 02:05 PM   #15
PedroJG
Update: I retarded my timing and it started up but idles horribly, i managed to take a video of it and its making a really weird ticking sound on the exhaust side, does anyone know what this means? also when i push the throttle the car just wants to stall?
Old 07-17-2014, 05:34 PM   #16
chriskilla2
chriskilla2 is an unknown quantity at this point
check fuses. happened to me, turned out to be the one of the Eng Cont fuse in the kick panel
chriskilla2 is offline   Reply With Quote
Old 07-17-2014, 07:29 PM   #17
PedroJG
Checked all the fuses and none of them are blown. I went to go start the car again to check and see if any of my cylinders are miss firing and the car wont even start Anyone know what that noise is in the video?
Old 07-17-2014, 09:06 PM   #18
Bushido
Bushido's Avatar
fuckin' yellow block dude...
i had to look at your location after seeing that...of course.
Old 07-17-2014, 09:23 PM   #19
PedroJG
Sorry to break your heart but thats not my engine (: its a picture that i grabbed off google so i could draw where i routed my coolant lines and vacuum lines, but nice try
Old 07-17-2014, 09:45 PM   #20
Greybush
Greybush is an unknown quantity at this point
Stupid question, but have you checked the ecu for codes?
Greybush is offline   Reply With Quote
Old 07-17-2014, 09:49 PM   #21
PedroJG
No stupid question here! Yes I did and the only code I got was 34 which is the Knock sensor.
Old 07-20-2014, 06:45 PM   #22
PedroJG
Update: I pulled off my fuel rail and i'm going to test the fpr and clean the injectors. I want to set my timing and i've done a bunch of research on how to do it but im a little confused on one part. Do i set the crank pulley to TDC or do I put on 20btdc?
Old 07-21-2014, 03:46 PM   #23
Nissan4Life87
Nissan4Life87 is an unknown quantity at this point
Did you check the harness? I just had the same issue with mine and when I redid the harness it didn't cut off anymore.
Nissan4Life87 is offline   Reply With Quote
Old 07-21-2014, 03:55 PM   #24
PedroJG
yes, it has a new harness and ecu
