Old 04-11-2012, 03:32 PM   #1
jacobzking
jacobzking is an unknown quantity at this point
help with japanese writing on my ECU?
this is the ECU that came with my motor. i can confirm the 550 injectors and z32 maf, but it says tome "something" and T67 (?) "something." the car definitely dopes NOT have a T67 turbo (came with s15 t28) so maybe that T67 is supposed to be 267 (cams?). tome head gasket maybe? any help would be appreciated!
also, I tried pulling off the valve cover to look at the cams, but couldn't find any markings, but i also know that the new Tomei cams are NOT marked... and I'm too mechanically stupid to pull them out to measure the lobes.
i'm trying to get an enthalpy tune ecu and want to give him as accurate info as possible
jacobzking is offline   Reply With Quote
Old 04-11-2012, 04:10 PM   #2
ILoveJDM
ILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to behold
t67 turbo, wouldnt be surprised if they took it off and throw on a different turbo
(h) is also a trust td06/t67 size
also - a trust/greddy td06 on an sr20 is a very common method of making 350whp in japan. which makes sense with your 550/z32 setup.
DODOlogic.ca
ILoveJDM is offline   Reply With Quote
Old 04-11-2012, 04:13 PM   #3
di-devol
di-devol will become famous soon enoughdi-devol will become famous soon enoughdi-devol will become famous soon enoughdi-devol will become famous soon enough
I just bought a set of Tomei cams, they ARE marked.
di-devol is offline   Reply With Quote
Old 04-11-2012, 04:17 PM   #4
va240dude
va240dude's Avatar
Trader Rating: (161)
va240dude is an unknown quantity at this point
Feedback Score: 161 reviews
Yeah I can confirm that mark after the T67 means a T67 turbo was used before....stinks about not knowing which Tomei cams were used though.
180SXオタクだ!
va240dude is offline   Reply With Quote
Old 04-11-2012, 04:26 PM   #5
ILoveJDM
what size?
i had an older set of poncams that werent marked.
OP needs to find the tools or someone to help him measure the lobes or he'll never know for sure.
DODOlogic.ca
Old 04-11-2012, 04:44 PM   #6
di-devol
256 poncams:
Old 04-11-2012, 05:00 PM   #7
lflkajfj12123
550 injectors
z32 maf
t67 turbo
tomei cams or ecu 身 = make / main part
ecu prob needs a full retune for your setup
Old 04-12-2012, 11:26 AM   #8
jacobzking
cool, thanks for your help guys!
Old 03-24-2020, 03:06 PM   #9
jimrhodes
jimrhodes is an unknown quantity at this point
You can always use this https://dissertationauthors.com/blog...rtation-in-mla service if you need help with writing. I think you could just write to them. But I am glad you solved this problem.
jimrhodes is offline   Reply With Quote
