Old 11-14-2019, 08:35 PM   #1
adrianm7
adrianm7 is an unknown quantity at this point
Question Starting Car
I am trying to figure out why the starter in my 1995 240sx is not engaging with the flywheel. Do 240sx motors need shims for the starter? Every time I turn the key the starter activates but it's misaligned with the flywheel so I have to cycle the key numerous times before the engine stops.
Does it need shims, a new starter or a new flywheel??
adrianm7 is offline   Reply With Quote
Old 11-15-2019, 12:52 AM   #2
5t341tH
5t341tH's Avatar
5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute
Send a message via AIM to 5t341tH
Take off the starter and check out the teeth on the gear and the flywheel. There are no shims
lexus baby
5t341tH is offline   Reply With Quote
Old 11-15-2019, 03:10 AM   #3
gaz_moose
gaz_moose is an unknown quantity at this point
I had a car like this once, I slackened off the starter bolts a bit then started the car a few times and it found its own place.
it could also be a sticky starter so you could strip and clean the throw out mechanism.
gaz_moose is offline   Reply With Quote
240sx
