05-31-2010, 08:17 PM | #1 |
s13 possible BHG?
ive been overheating like crazy going like 3miles from my house.
at idle stays in the middle, once i start driving it gets HOT! i replaced radiator, water pump, and thermostat. hoses dont seem to be clogged. when i turn my car off and go do something and come back to start it, it bogs until i rev it up for a couple seconds then sounds normal? any help would be appreciated. |
06-01-2010, 02:08 AM | #5 |
gonna do a pressure check tomorrow, also after driving for about an hour, if it doesnt overheat it gets hot and when i turn it off my coolant res tank boils
07-04-2010, 04:29 AM | #11 |
check your oil is it milky white??
if it is your coolant and oil are mixing could be a bad hg or a crack on block try doing a conpresion test also. make sure clutch fan is working properly. have you replaced thermostat? |
07-04-2010, 03:23 PM | #12 | |
yes i have, but bought one from autozone which i heard was a bad idea cause theyre faulty, and it didnt work. i saw coolant leaking from looked like the exhaust mani, but could it have been from a crack? or the hg? |
07-04-2010, 05:20 PM | #13 |
do you see the leaking from outside the mani or coming from within?
what about your oil?it will be a major indication by its color. also if its a head gasket you will see constant white smoke from your exhaust because the water is heat up vaporized and shot out the exhaust as white smoke. |
