Old 01-26-2006, 08:01 PM   #1
sifu
sifu is an unknown quantity at this point
rough idling after 5 speed swap complete
i finally finished my s14 auto to 5speed swap but now i'm getting a rough idle when i start the car. it dies below 1k rpm in neutral
this is after a test drive
i'm running an auto ecu. crankshaft sensor is broken. could it be on my intake somewhere, IACV? could it be because of any of the sensors on the tranny?
sifu is offline   Reply With Quote
Old 01-26-2006, 08:09 PM   #2
SaGang227
SaGang227 is an unknown quantity at this point
It could be vacuum leak.
Check to make sure that you don't hear any air leak when idling.
SaGang227 is offline   Reply With Quote
Old 01-26-2006, 08:32 PM   #3
NemeGuero
No more nissan.
NemeGuero's Avatar
Try replacing the ECU, check for vacuum leaks, get the CAS fixed, clean the IACV, and then report back.
Old 01-26-2006, 11:54 PM   #4
jdm538
jdm538's Avatar
Trader Rating: (30)
jdm538 is close to perfectionjdm538 is close to perfectionjdm538 is close to perfectionjdm538 is close to perfectionjdm538 is close to perfectionjdm538 is close to perfectionjdm538 is close to perfectionjdm538 is close to perfectionjdm538 is close to perfectionjdm538 is close to perfectionjdm538 is close to perfection
Feedback Score: 30 reviews
im not sure but i dont have any sensors connected from the tranny besides the speed and reverse, also i ran with an auto ecu with no problem. i have a s14 with s13 tranny. no problems i dont think it have anything to do with setup you might have hit something during the swap.
jdm538 is offline   Reply With Quote
Old 01-27-2006, 08:08 AM   #5
Lith
Lith will become famous soon enoughLith will become famous soon enoughLith will become famous soon enoughLith will become famous soon enoughLith will become famous soon enough
Send a message via ICQ to Lith Send a message via AIM to Lith Send a message via MSN to Lith Send a message via Yahoo to Lith
it's the Auto ECU. Rev the car a bit once you start it up. That happens because you took out the Automatic Tranny control unit when you put the clutch pedal in.
edit: getting 5spd. ecu would solve that problem
Lith is offline   Reply With Quote
Old 01-27-2006, 11:06 AM   #6
sifu
i have a 96 manual ecu, i'll put that in and put my new crank position sensor in.
