Old 02-16-2006, 02:53 PM   #1
clutch kick drifter
clutch kick drifter's Avatar
clutch kick drifter has a spectacular aura aboutclutch kick drifter has a spectacular aura aboutclutch kick drifter has a spectacular aura aboutclutch kick drifter has a spectacular aura aboutclutch kick drifter has a spectacular aura aboutclutch kick drifter has a spectacular aura about
SR20det.. how to get to TDC
I need to know how to get the SR20det to TDC. CAn i just turn the crank until the ____ mark?
clutch kick drifter is offline   Reply With Quote
Old 02-16-2006, 02:55 PM   #2
sblack13
sblack13's Avatar
sblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud of
http://www.frsport.com/sr20det-crank...ide-p-648.html
sblack13 is offline   Reply With Quote
Old 02-16-2006, 02:56 PM   #3
Silverbullet
Silverbullet's Avatar
Silverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really nice
Send a message via AIM to Silverbullet
TDC stands for top dead center. It ususally refers to the piston. All the pistons are in different positions so it would be best if you specified which piston. When in terms of timing a motor, you want the first piston to be at TDC. I'm assuming thats what you mean so here is how to do so. You will need a 27mm socket to turn the crank. There are mating marks that you can match up. There are 4 i believe. You want the reference dot to be lined up with the 2nd dot from the left. I hope that was clear.
HouseBuyers365.com
Originally Posted by Flybert
Go back to whatever Honda forum you came from.
Silverbullet is offline   Reply With Quote
Old 02-16-2006, 02:59 PM   #4
wootwoot
wootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to all
Send a message via AIM to wootwoot
Pull out your spark plugs as well, makes turning the motor over much easier =)
I dare you to turn it over while its in gear with no parking brake!
I'm from Florida so I'm probably a bit more strange than you
wootwoot is offline   Reply With Quote
Old 02-16-2006, 03:08 PM   #5
clutch kick drifter
Number one piston. So the turning the crank with the 27 mm socket will get the #1 piston at TDC?
Old 02-16-2006, 07:59 PM   #6
g2ic02
g2ic02 is an unknown quantity at this point
Send a message via AIM to g2ic02 Send a message via MSN to g2ic02
yeah but you are gonna want #1 piston at tdc on the compression stroke if you are concerned with timing. What are you needing to set the motor at top dead center for? that would help everyone tell you how to do it. There is 2 tdc's for piston #1 in one complete combustion cycle. If you are pulling the valve cover off there is a mark on the timing gears. Hopefully this helps
g2ic02 is offline   Reply With Quote
Old 02-16-2006, 08:16 PM   #7
clutch kick drifter
Im installing the new CAS. I know everyones gonna say ohh you have to take the valve cover off but you dont. A friend of mine put my new one in without taking valve cover off. I wasent there to watch though.
Old 02-17-2006, 09:46 AM   #8
killjoy
killjoy's Avatar
killjoy is an unknown quantity at this point
Send a message via AIM to killjoy
You are right, you don't. Only if you want to verify that it is correct.
stolen s13
new stock non-stolen s13
killjoy is offline   Reply With Quote
Old 02-21-2006, 02:46 AM   #9
daryl337
daryl337's Avatar
daryl337 has a spectacular aura aboutdaryl337 has a spectacular aura aboutdaryl337 has a spectacular aura aboutdaryl337 has a spectacular aura aboutdaryl337 has a spectacular aura aboutdaryl337 has a spectacular aura about
Send a message via MSN to daryl337
well, or if you want to keep pulling it out and turning it one tooth over until you get it right. :P
To install the CAS... pull the valve cover off... turn the main pulley to the TDC mark (the second one from the left) and then look at your camshafts. Your cam lobes should be pointing away from eachother (on your number 1 cylinder.. assuming your camshafts are timed right).... If they dont point outwards... rotate the pulley 360 degrees... then you will be on TDC on your compression stroke.
Now that you have the motor set to TDC properly... take the CAS... and align it so when you push it in... the alignment marks on the CAS line up. Plug it in... start the car... and stick a timing gun on it to make sure you are sitting at 15 degrees advance.. and voila! =D
daryl337 is offline   Reply With Quote
