Old 05-13-2006, 06:16 AM   #1
fireheadmt
fireheadmt is an unknown quantity at this point
Send a message via AIM to fireheadmt
sr wont start
1990 hatch w/ redtop (late model, fins in head).
right off the bat, not getting any fuel or spark.
oil pressure sending unit is not hooked up
power steering lines are not plugged in
none of the tranny plugs are plugged in (reverse, neutral switch, etc.)
the motor cranks but no spark, and fuel pump does not even come on when i turn the key on or when i crank it. but if i send power manually to the pump it comes on so i know its a good pump
other than what i said above, everything is plugged in and grounds are tight
grounded at the head and intake manifold
i thoguht maybe bad ecu, so i have another on its way. but any other ideas?
what am i missing here?!?! im so anxious to get this started
thanks - matt
fireheadmt is offline   Reply With Quote
Old 05-13-2006, 06:22 AM   #2
street_white180sx
street_white180sx's Avatar
street_white180sx is an unknown quantity at this point
SR
ok start off by checkin if there is a ground signal goin to the fuel pump relay from the ecu. i had this prob b4 and i jus bypassed the ground and ran my own ground from the fuse box to the chassis of the car. the fuel pump fired right up. and for no fuel or spark check your crank angle sensor along with the wiring goin to it. also did you remove the crank angle sensor at anytime and jus popped it back in there if so your ignition will be off and you will have to reinstall the sensor. hope this helps.
1993 S14 Silvia Slant Top, Blitz Bov, Fmic, Catback exhaust, HKS evc 3
street_white180sx is offline   Reply With Quote
Old 05-18-2006, 09:13 AM   #3
kevtrinh
kevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond repute
where is the fuel pump relay?
nvm i found it on another post....
kevtrinh is offline   Reply With Quote
