Old 05-26-2002, 09:22 PM   #1
Natty
Natty is an unknown quantity at this point
I have a 5 speed 1991 Fastback with 150,000 on the odometer.
I have some wierd vibrations around 50 to 60 mph and also from 2k to 3k rpm.
Then again, when braking, I get really really bad vibration and the car goes side to side?
Could this just be rotors, or something more?
Thanks &nbsp;<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/thumbs-up.gif" border="0" valign="absmiddle" alt=':thumbsup:'>
Jeff
1991 White 240sx Fastback LE, rusty spoiler, weak driveshaft, exhaust rattle....
Rattles are just your cars way of saying 'I love you.'
Natty is offline   Reply With Quote
Old 05-26-2002, 10:09 PM   #2
rampid360
rampid360 is an unknown quantity at this point
Send a message via ICQ to rampid360
Probably not your rotors because it shakes under circumstances where you are not braking. &nbsp;
1. Simple alignment or wheel balance problems would cause shaking at 50-60
2. T/C rod bushings would cause shaking while accelerating, braking and at certain speeds. &nbsp;(this is probably your problem)
Check your T/C bushings first since it doesn't cost anything to look. &nbsp;If they're shot, replace them.
If your car is near maintainance time, take it in and get the alignment done anyways...cant hurt.
-Al
For every winner there are dozens of losers. &nbsp;Odds are you're one of them.
rampid360 is offline   Reply With Quote
Old 05-27-2002, 08:17 AM   #3
Natty
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (rampid360 @ May 26 2002,12:09)</td></tr><tr><td id="QUOTE">Probably not your rotors because it shakes under circumstances where you are not braking.
2. T/C rod bushings would cause shaking while accelerating, braking and at certain speeds. (this is probably your problem)
Check your T/C bushings first since it doesn't cost anything to look. If they're shot, replace them.
-Al</td></tr></table><span id='postcolor'>
Doesn't look like any of my bushings are shot. They could be better though.
I'll put new rotors in when I re-do my brakes later in the summer.
I had an alignment done 4 months ago, and I get a 6 month warranty if it gets knocked out. The tires were balanced too. I asked the guy to rotate them, but he said that th rears were far too shot to be rotated. I would have to buy new ones. I forgot about that, maybe it is my tires.
I'll have it checked out tomarrow...
Thanks guys &nbsp;<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/thumbs-up.gif" border="0" valign="absmiddle" alt=':thumbsup:'>
Jeff
Old 05-27-2002, 03:45 PM   #4
mbmbmb23
Zilvia Contributor
mbmbmb23's Avatar
mbmbmb23 is on the path to ruinmbmbmb23 is on the path to ruin
Check to see if you have a steel belt broken on a tire.
-m
400x200
mbmbmb23 is offline   Reply With Quote
