Old 02-24-2006, 06:58 PM   #1
Aldus
Aldus is a well-known jackass
dohc wiring
Im doing the dohc swap and everything is working fine in the guide except for one piece of wiring inside of the engine bay.
Under the fuse box near the battery there is a connector on the dohc body that has 2 prongs and has a yellow / blue and a yellow / red wire coming out of it. On the sohc it is a connector that has 4 wires on it red /blue, orange, yellow / blue, and black. Im assuming I need to splice these wires together to get everything working, but Im not sure which to splice the dohc body connector onto. Im guessing either the yellow / blue to the yellow / blue and the yellow / red to the red / blue or the yellow / blue to the yellow / blue and the yellow / red to the black.
Ive searched all over for info on this but I havent been able to fine anything.
Any help appreciated.
Chris
Aldus is offline   Reply With Quote
Old 02-25-2006, 02:38 PM   #2
Aldus
Connector coming out of the dohc engine harness (plugged into the cut dohc body harness plug)
4 wires from the sohc body harness with the plug cut off
another picture of the 4 wires
picture of the plug on the sohc engine
another pic of the sohc engine harness plug
overall pic of the area
the dohc plug
The engine is turning over and cranking but there is no spark at all. Im going to get the coil checked right now, but it was working fine while in the other car.
Old 02-25-2006, 03:30 PM   #3
Aldus
Coil is fine, just got back from getting it tested.
