Old 02-24-2006, 09:24 AM   #1
AuburnRyan
AuburnRyan is an unknown quantity at this point
3 peice wheels owners - how often do you reseal?
So I've got my volk 3 peice set used form JDM land. They have white silicone in the "valley" where the 2 rim pieces and face meet - LOL.
Should I reseal them before I mount new tires? How -
- should I overlay the old silicone in the middle of the wheel,
- or ultra PITA take the wheels apart, remove old silicone, reseal, and assemble. Is this necessary?
Everyone using home depot SPL silicone or anything special?
This process must be the downside of three peice wheels
'93 Fastback LE - Wrecked
'91 Fastback HICAS and LSD - Sold
'93 Fastback SE - Current
AuburnRyan is offline   Reply With Quote
Old 02-24-2006, 09:33 AM   #2
KiDyNomiTe
KiDyNomiTe's Avatar
KiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond repute
Send a message via AIM to KiDyNomiTe
Never had to do it, but know someone that did it, but because he wanted to switch lips.
Unless you think the silicone is weak don't bother...
PROCEED
Grip Gambler
KiDyNomiTe is offline   Reply With Quote
Old 02-24-2006, 09:34 AM   #3
AuburnRyan
According to the internet (below) - but is anyone having issues with leaks etc. I'm not planning on yearly maintainence, but will do what's necessary to avoid issues. i.e. when tires are already off for any reason.
" Two & Three piece modular wheels require periodic maintenance. You'll want to work out your own maintenance schedule, but here's an example of what the manufacturer recommends.
Each Season disassemble, thoroughly inspect, clean, re-seal, and re-torque each wheel:
Replace wheel bolts each season
Wheel Bolt Torque:
1/4" bolts 15 ft/lbs. or 180 in./lbs
5/16" bolts 20 ft/lbs.
After thoroughly cleaning all mating surfaces with an appropriate cleaner, add a thin skim coat of silicone sealant to these surfaces, assemble wheel and torque bolts to recommended torque
Install a new valve stem
Add a thick coat of silicone sealant to the drop center area of the wheel and let it cure for 24 hours before initial use
Below is an example of cracking which can occur on wheels which don't support the back rim half with the center. This wheel happens to be a Dura-lite wheel.
Modular Wheel Leak Detection
So your tires keep going flat, before you blame those leaky slicks, check your wheels for leaks.
Inflate the tire/wheel combination to 40psi
Spray a solution of soapy water onto the wheel
Mark areas where bubbles appear with a tire crayon
If leaks in the wheel are found follow the maintenance procedure above to reseal the wheel
The most common cause for leaking modular wheels is; the tire changing person has stuck their tire spoon into the silicone seal and damaged it during a tire mount."
Old 02-24-2006, 09:38 AM   #4
KiDyNomiTe
KiDyNomiTe's Avatar
Meh, Im sure my 3 piece wheels have been in use for years and I have no idea where to get work bolts and wouldnt want to lose them...
PROCEED
Grip Gambler
Old 02-24-2006, 11:05 AM   #5
s14xman
s14xman's Avatar
s14xman is a glorious beacon of lights14xman is a glorious beacon of lights14xman is a glorious beacon of lights14xman is a glorious beacon of lights14xman is a glorious beacon of lights14xman is a glorious beacon of lights14xman is a glorious beacon of lights14xman is a glorious beacon of lights14xman is a glorious beacon of lights14xman is a glorious beacon of lights14xman is a glorious beacon of light
Send a message via AIM to s14xman
i don't think it's that big of a deal, i have never had any problem with my two piece. besides there are like a million of fasteners and i'm too lazy. I wouldn't worry about it unless they are showing signs
FRontline (marinating since 02)
s14xman is offline   Reply With Quote
Old 02-24-2006, 12:24 PM   #6
the head
the head's Avatar
Had a daily driver/auto x car that ran A032R tires that I replaced every summer I had three peice wheels on it never resealed them and i had the rims for four years that shit is BS unless they are leaking leave them alone
Old 02-24-2006, 12:55 PM   #7
chmercer
chmercer's Avatar
i resealed one of mine when i took it apart to paint it. otherwise the other 3 have never been touched. theyre probably at least 5 years old.
chmercer is offline   Reply With Quote
Old 02-25-2006, 12:48 AM   #8
studio
studio's Avatar
studio is an unknown quantity at this point
10 to 15 years that what ive heard but just look for cut or holes in the seal. if there is any then you need to worrie.
studio is offline   Reply With Quote
