Old 02-25-2006, 12:24 AM   #1
daemon240sx
daemon240sx is an unknown quantity at this point
ca18det ecu on ka24de
First off im new to the forum...
Hi everyone!
ok my question is is it possible to use the ca18det ecu on the ka24de.
i havea ca18det ecu socketed with a eprom programmed to the ka24de only to find out tonite that the plugs are different. is there anything i can do or some kind of adapter i can buy to make the thing work.
edit* Forgot to mention i drive a champaigne colored 93 240sx fastback with a 5-speed
and that the whole reason for the eprom and ecu was to use a q45 maf. i have the eprom programmed to accomadate the q45 maf (supposedly)
daemon240sx is offline   Reply With Quote
Old 02-25-2006, 12:49 AM   #2
!Zar!
!Zar!'s Avatar
Umm... ...no...Just go buy a doch ecu. They can be had for cheap.
Old 02-25-2006, 12:56 AM   #3
daemon240sx
im using the stock ecu right now. i wasa going to use the ca18 ecu because it has the prom option without a daughterboard. so there is no way to convert to use the ca ecu?
Old 02-25-2006, 01:30 AM   #4
sdtouge
sdtouge can only hope to improve
you could but it would suck. just get a safc or greddy emanage if you want to do your own tunes. youd have to repin/rewire almost if not everysingle wire to the corresponding pin. a guy use a sr ecu on ca, he just made a adapter harness and then tuned the sr ecu since he worked at jim wolfe.
anyways i would just get emanage honesttly, but ineresting idea. i think sohc ka might be easier and i beleive that is as reprogambel as ca.
sdtouge is offline   Reply With Quote
Old 02-25-2006, 08:07 AM   #5
boosteds13
boosteds13's Avatar
boosteds13 is just really niceboosteds13 is just really niceboosteds13 is just really niceboosteds13 is just really niceboosteds13 is just really niceboosteds13 is just really niceboosteds13 is just really niceboosteds13 is just really nice
I dont see how this would work at all... CA ecu = 8-bit, KA ecu = 16-bit. CA = distributorless, KA = distributor.
"A CA? WTF is that? You shoulda got an SR yo."
View my vBPicGallery!
boosteds13 is offline   Reply With Quote
Old 02-25-2006, 05:11 PM   #6
BigVinnie
BigVinnie's Avatar
BigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfection
It would work.
It's just like rigging up a haltech that uses distributorless.
Mad hours would need to be done in order to splice a harness. Then consider more hours to install all the individual coils for the CA18det ecu. Not worth it in my opinion.
Unless you go KA24DET then I would suggest to try something like that since the ecu is already mapped for boost, and the rod/stroke ratio between the 2 engines are similar. It would probably make better HP numbers than the KA24de stock ecu with no retune.
8bitters are a bit outdated, but they are super easy to tune (with a cheap rom editor).
If you want to make your own Nissan OEM clip and harness you can purchase the parts at www.digikey.com
BigVinnie is offline   Reply With Quote
Old 02-25-2006, 06:02 PM   #7
daemon240sx
well if i cant use the ECU its up for sell. CA18DET ecu #78 i believe. comes with a socket to drop a prom chip in no prom included. $50 bucks or best offer
Old 02-25-2006, 08:07 PM   #8
sdtouge
post it on nicoclub.com ca section, they love that shit.
Old 02-25-2006, 08:33 PM   #9
boosteds13
boosteds13's Avatar
I sold a guy a set of injectors on there for $190 shipped, then bought them back two months later from the same guy for $150 shipped.
