Old 01-31-2004, 10:07 AM   #1
bchumley
bchumley is an unknown quantity at this point
picture of Heavy Throttle heater hoses?
Hey, I bought those easy fit heater hoses from Heavy Throttle. The motor's already in the car, and I can't tell just by looking at them which one goes where. Heavy Throttle had a picture on their site I thought showing where they go, but I can't open it anymore. Anyone else maybe have a picture to help me out?
Bret
http://www.cardomain.com/memberpage/687020/1
bchumley is offline   Reply With Quote
Old 01-31-2004, 10:53 AM   #2
HiPSI
HiPSI is an unknown quantity at this point
Send a message via AIM to HiPSI Send a message via Yahoo to HiPSI
ummm, you can't really get to the lines coming from the motor with the engine in the car.... so either way good luck to you sir
SR motor set/clip $2500+, FMIC kit $700+, Downpipe $100+, 3" exhaust $500+, Misc install parts $100+, Shop labor for install $1000+ and you still only make 220rwhp for $5000
so what's so CHEAP about the SR swap again?
HiPSI is offline   Reply With Quote
Old 01-31-2004, 10:57 AM   #3
TheSparo
Location: Athens/Chattanooga/ Cookeville/Morristown, TN
TheSparo is an unknown quantity at this point
Send a message via AIM to TheSparo
i put them in after i had the motor in... (my ghetto setup) so im sure he can too...
89 240 SR powered...
ummm i promise its stock
TheSparo is offline   Reply With Quote
Old 01-31-2004, 01:14 PM   #4
kcolyer27
kcolyer27's Avatar
kcolyer27 is an unknown quantity at this point
they still have themon ebay...
kcolyer27 is offline   Reply With Quote
Old 01-31-2004, 01:21 PM   #5
HiPSI
i'd be willing to wager my setup is more ghetto... but i sure wouldn't want to try to put them in with the engine in.
Old 01-31-2004, 08:16 PM   #6
oberkill
oberkill is an unknown quantity at this point
Its not that hard to get them on with the engine in. Its not that easy either though! lol
As for the hoses. The one that has the 180 degree turn goes onto the pipe on the back on the engine facing towards the passenger side, the L shaped hose goes from the top connection on the firewall to the 180 degree hose. Use the connector provided to hook them together, you will probably need to trim one of the hoses to clean it up some. The other hose goes on the lower firewall connection to the pipe coming out under the intake. Remove the valve cover to get more room to reach the pipe on the back of the engine. Also spray a little WD40 inside the hoses and it will go on allot easier.
Alan
http://www.project240.com
oberkill is offline   Reply With Quote
Old 02-02-2004, 07:10 PM   #7
kazuo
kazuo will become famous soon enoughkazuo will become famous soon enoughkazuo will become famous soon enoughkazuo will become famous soon enoughkazuo will become famous soon enough
I put them in with the motor in the car. It can be done.
But say goodbye to the skin on your knuckles.
kazuo is offline   Reply With Quote
Old 02-02-2004, 11:09 PM   #8
bchumley
yep, they are now in there. and yep, my hands hurt like hell. thanks for the help Alan, it really was useful.
Bret
Old 02-15-2004, 09:08 PM   #9
SR PwrdVA
SR PwrdVA is an unknown quantity at this point
Yeah that kit isn't hard at all to get in with the motor in, just takes alotta patience and the motivation of 15 degree weather outside, lol
SR PwrdVA is offline   Reply With Quote
Old 02-27-2006, 09:07 PM   #10
g6civcx
g6civcx's Avatar
I was able to install new heater hoses with the motor in the car. A couple of tips for you:
* The Heavy Throttle kit consists of the following parts:
1) One 3/4" U hose.
2) One 5/8" L hose.
3) One 3/4" S hose.
6) One 3/4" to 5/8" reducer.
7) 6 hose clamps.
1/2/6 are used for the upper heater hose. 3 is for the lower. The upper hoses need to be trimmed to fit, and fit with no problems once you mount them.
The lower hose #3 is the one that is the problem. This is Gates part number 19606. The specs for this part is below for your reference.
As you can see below, this part is 3/4" throughout. The JDM SR nipple is 3/4", but since the USDM heater core is 5/8", this will not work. I installed this part and the hose was leaking at the heater core because it was 1/8" too large.
What I had to do was to make a custom hose, using a 3/4" to 5/8" reducer. The lower hose that was supplied with the kit was useless.
$35 + shipping is a good price if you don't want to piece together your own kit, but since the lower hose was useless to me, it wasn't worth it to me. You can get the U, the L, and the reducer for probably $15-20. Add a few more bucks for clamps and you're good to go.
I'm not knocking Heavy Throttle at all. I'm just commenting on their products from what I saw. They should really redo the lower hose for the kit.
Product ID 42570044
Part # 19606
Product Description
19606 SID COOLANT HOSE
UPC 072053178388
Category Hierarchy
Automotive -> Hose -> Small I.D. Coolant Hose
Specifications
Centerline Length (In.) 11.6
Inside Diameter 1 (In.) .75
Weight
Weight (Lbs.) 0.32
Old 02-27-2006, 09:23 PM   #11
scarecrow
scarecrow's Avatar
scarecrow has a little shameless behavior in the past
SR heater hoses
man heater hoses can suck on sr swaped 40's. went getto first but started to leak 7 months later. it can be done after the engine is in but drink up and take your time and do it right the first time around.
scarecrow is offline   Reply With Quote
Old 03-01-2006, 08:32 PM   #12
DUBCITY
DUBCITY's Avatar
DUBCITY has much to be proud ofDUBCITY has much to be proud ofDUBCITY has much to be proud ofDUBCITY has much to be proud ofDUBCITY has much to be proud ofDUBCITY has much to be proud ofDUBCITY has much to be proud ofDUBCITY has much to be proud ofDUBCITY has much to be proud ofDUBCITY has much to be proud ofDUBCITY has much to be proud of
1) One 3/4" U hose.
2) One 5/8" L hose.
3) One 3/4" S hose.
7) 6 hose clamps.
Product ID 42570044
Part # 19606
Product Description
UPC 072053178388
Category Hierarchy
Specifications
Weight
Weight (Lbs.) 0.32
Thanks for the post. Any chance you can tell me the part numbers for the hoses that did work?
Keep your eyes peeled for Project DUBCITY!
DUBCITY is offline   Reply With Quote
Old 03-01-2006, 08:56 PM   #13
g6civcx
g6civcx's Avatar
Sure thing. The U is Gates 19666. The L is Gates 28467. You can find the nearest retailer near you here: http://www.gates.com/automotive/dist...ocation_id=539
The 5/8" to 3/4" reducer is just a standard hard plastic reducer you can get at any auto parts store. Same goes for the hose clamps.
Since everybody thinks that this is a difficult job (wasn't that difficult, just frustrating), I am completely redoing the heater. I am going to order a new heater hose, and have a shop weld on 3/4" fittings instead of the 5/8" fittings that normally come on the US-spec car. Then I will order a metre of Samco 3/4" Superflex hose and cut them to length.
I'll keep you guys updated of how it works out.
