Tie rod install clarification
1.) I'll be alright by just using the locking plate (had to bend it back into place) and no locktite, right?
2.) I bought some s14 tie rods (same part # as moog), but there wasn't a nut to tighten against the tie rod end on the inner rod. Should I buy them? Or is it alright like it is? If not, is that where I should probably use locktite? 3.) If I torque the tie rod end (and control arm joint) down, wont this compress the ball joint boots down (smoosh them)? Thanks. |
you should have a nut to go with the side where the tie rod end is.... for the other side just use the locking plate... i changed mine about 3000 miles ago and mine is fine with no locktite... even with some drifting on them
#3 | |
#8 | |
![]() Join Date: Dec 2002
#9 | |
I have s14 tie rods (complete). I was saying they maybe didnt anticipate that I would be going from s13 rods -> s14 rods, so they may not have given "jam nut". And that castle nut, that should be torqued down, regardless if it smooshes the balljoint boot/bushing? |
#12 | |
AFC #1
![]() Join Date: Oct 2003
#13 | |
#14 |
AFC #1
The rod is tapered to get tighter as you tq down. I checked the fsm. it's 22-29 then tighten to the next notch on the king nut to slide the cotter pin in. Never exceeding 35ftlbs.
#15 | |
So I guess thats: Yes, I can install without the locktite + locking plate. Yes, I need the locking nut. And I still need to torque to specs to the next notch for cotter pin. Thanks a lot guys! I already ordered the locking nut for the tie rod end (OEM) along with some other bolts I'll need to replace. |
#16 |
before taking apart the stock end, either measure it or count the turns needed to take it apart. That way the toe will be close enough to drive in for an alignment.
Or you can always use a tape measure on the tires, i guess. I ended up doing that on the side of the interstate inroute to a drift day for a friend.
ASE Master Technician |
#17 | |
What is this tape measure method of measuring toe? |
#18 | |
#19 | |
