Old 03-27-2006, 02:40 AM   #1
komedy
komedy is on the path to ruinkomedy is on the path to ruin
which is for hotpipe and which is for cold?
is the top outlet thats is connected with the stock bov on the stock smic for the cold pipe and the botton outlet for the hot pipe?
sorry trying to load pic.
komedy is offline   Reply With Quote
Old 03-27-2006, 03:40 AM   #2
g6civcx
g6civcx's Avatar
Ideally the compressor bypass valve (CBV) would sit on the hotpipe. The factory chose to put it on the coldpipe. If you can enlarge your picture I can circle it for you. If not I'll take a pix of my sidemount for you.
Old 03-27-2006, 03:44 AM   #3
komedy
sorry it wont let me enlarge because of some kind of limit on the image?
so the pipe with the bov is for the hot pipe or cold pipe?
Old 03-27-2006, 03:55 AM   #4
g6civcx
g6civcx's Avatar
Do you know what the terms BOV, CBV, hotpipe, and coldpipe mean?
I'll get you a picture later on. It should clear up everything for you.
Old 03-27-2006, 03:05 PM   #5
komedy
sort of. the hot pipe is from the turbo to intercooler and the cold pipe is from the intercooler to the throthle body? i dont know what CBV is tho?
Old 03-27-2006, 04:03 PM   #6
93 240sxfastback
93 240sxfastback is an unknown quantity at this point
When you bolt up the intercooler the piping should become obvious. It lines up.
93 240sxfastback is offline   Reply With Quote
Old 03-27-2006, 04:26 PM   #7
komedy
ic then the cold pipe is the one with the stock bov atached to it
Old 03-27-2006, 08:33 PM   #8
g6civcx
g6civcx's Avatar
That's right. You got it.
I snapped some pix for you below. From the top, the hose that's disconnected is the hotpipe. It's disconnected because my turbo is out right now. The other hose is your coldpipe. The blue silicone taps the coldpipe for your wastegate.
On the bottom view, the CBV was removed and the piping capped.
P.S. Don't mind the pink slippers. I swear they're not mine
