Old 03-25-2006, 04:24 PM   #1
xagna
xagna has a little shameless behavior in the past
Wheel hop is back!
Had rear subframe spacers on for about a week. When I first installed, it got rid of wheel hops, particularly on the uneven corner surfaces. But now the wheel hop is back.
Does this mean that the subframe bushings got even more smaller due to spacers and that spacers are not doing their job?
xagna is offline   Reply With Quote
Old 03-25-2006, 04:29 PM   #2
sidewayzs13
sidewayzs13 is an unknown quantity at this point
ive always heard the the subframe spacers are just a big waste of money. so yes that could be the cause
sidewayzs13 is offline   Reply With Quote
Old 03-25-2006, 07:25 PM   #3
kandyflip445
kandyflip445's Avatar
I love my spacers. They made a big difference. Make sure it's still tight and then start checking out other parts of the suspension.
My 240 vBgarage
Old 03-25-2006, 08:05 PM   #4
gotta240
gotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfection
take the 8 or 10 hours and replace the subframe BUSHINGS.
gotta240 is offline   Reply With Quote
Old 03-25-2006, 09:01 PM   #5
krustindumm
krustindumm's Avatar
krustindumm is an unknown quantity at this point
8-10 hours, come on. It's like 2.5hrs max! Or maybe it's just because of all these damn altima's, maxima's, and Z's.
ASE Master Technician
krustindumm is offline   Reply With Quote
Old 03-25-2006, 09:05 PM   #6
Irukandji
Wheel hop is inevitable. I have rear subframe spacers, and coils and my rear still hops once in a blue moon.
I wouldn't worry about it.
Old 03-25-2006, 11:22 PM   #7
xagna
When my rear wheels loose traction at bumpy hairpin everytime, this is a big problem. Not only that I spent $60 for nothing. Pisses me off.
Old 03-26-2006, 12:25 AM   #8
Irukandji
I wouldn't say that you wasted $60 considering those spacers will prevent your subframe from shifting, making your rear end feel more stable. And keep in mind $60 is a bargain for subframe spacers to begin with. It's always good to stay optimistic. What suspension are you running? Poor dampening could be the cause of your wheel hop.
Old 03-26-2006, 12:39 PM   #9
xagna
You are right on your own. But it doesnt feel any more stable than before installing the spacers.
Have megan coilover.
Is there anything I can do about this besides retorquing the subframe?
Old 03-26-2006, 12:59 PM   #10
s14slide
s14slide's Avatar
s14slide is an unknown quantity at this point
Send a message via AIM to s14slide
did you inspect the subframe bushings before the spacer install? Might want to check that, cuz the spacers won't help much if the rubber they're trying to compress isn't there to do so. Worn bushings on the suspension arms can also cause wheel hop, inspect those too. Shoot back here if you find something. Hope this helps. BTW, I have spacers too. Full circle aluminum and everything but the lower A arm is heim joints and I still get a small bit of wheel hop in the tight stuff and I'm running Megans too.
= My day
s14slide is offline   Reply With Quote
Old 03-26-2006, 09:18 PM   #11
xagna
There were bushings left in the subframe.
Now I'm assuming that the bushings have completely collapsed.
Well... thanks for the advices. I will inspect other bushings in the area.
