Old 12-06-2004, 10:15 AM   #1
Diabel
Diabel is an unknown quantity at this point
S14 RUCA ramoval problem...
I am trying to swap my stock RUCAs with the adjustable ones. I can't remove the inner bolt (the one that adjusts the camber). I took the nut off and bolt turns all the way around but I can't remove it, it's stuck. Didn't have any issues with the outer one...
Does it have to be in any special position to come out or do I just hammer the hell out of it?
THX
Diabel is offline   Reply With Quote
Old 12-06-2004, 10:54 AM   #2
Dousan_PG
Dousan_PG's Avatar
it has a notch on it and should slide thru that
if your ruca bolt is all messed up yeah hammer it out but it takes awhile
ive had mine stuck numerous times just takes some good ol elbow grease and a BFH
Aaron
Pink GodziRa
Old 12-06-2004, 10:57 AM   #3
projectRDM
projectRDM's Avatar
The last time it was aligned the mechanic overtightened the bolt, now the backing washer has spun out of the groove in the bolt. Only way to get it out is prying and beating.
Do yourself a favor and replace it with a standard bolt, with larger washers to keep it centered. Since you're installing an adjustable arm you no longer need the OE adjustment.
FORMERLY R240NA
Old 12-06-2004, 09:30 PM   #4
Diabel
Thank you for your help. I'll give it a try.
Old 03-28-2006, 06:13 PM   #5
TurK
TurK is making his/her stupidity well-knownTurK is making his/her stupidity well-knownTurK is making his/her stupidity well-knownTurK is making his/her stupidity well-knownTurK is making his/her stupidity well-known
Send a message via AIM to TurK
fuck im having the same problem....and hammering doesnt seem to be helping ?!?!?! damn it
TurK is offline   Reply With Quote
Old 03-28-2006, 08:00 PM   #6
TurK
DONE......HAMMER TIME Baby!
