Hoses
2 part Question:
I have a hose leaking, the one coming from my power steering fluid resivore and running to somewhere, What kind of hose is that? Can I replace it? Is there a part number? Second, I want to cut my upper radiator dose in order to install a temp gauge adapter. What is the best way to do this? Thanks |
There are Two Hoses coming off of Power Steering Reservoir. A Suction Line and a Return. Part Nos. are 49717-70f00 and 49725-70f00 respectively. Cost $28.91 and $27.92. Dealerships have Diagrams so they can tell you which one you will need, I just got finished replacing both. For cutting your Hose you can just get a Hacksaw Blade for like 2 Dollars from any Hardware Store.
![]() Join Date: Apr 2004
What kind of car is this?
For the temp sender, you'll need an adaptor that goes in between the hose if you don't already have one. Just use a sharp knife and use a hose clamp as a template to help you start the cut. Take off about 1" or so and fit the adaptor in between. |
This is an S13.
I believe the upper radiator hose is 37mm but couldn't I use a 1' 1/2" adapter from autometer? A hacksaw huh? That wouldn't fray up the hose? I'll give it a try. I'm actually installing a Oil psi, oil temp, water temp and replacing the PS resevoir hose this weekend. I'm useing a Greddy filter adapter to run the oil gauges. Is it cool to connect the pressure sender direct or should I have it remotely mounted? Thanks for the part #. |
I wonder if it is possible to use a OEM water temp sensor from the 89 240sx to mount my water temp gauge?
You know the one located on the lower rad hose. Its got a temp sensor attached to a small pipe. |
Instead of the OEM hoses for the PS, find some 3/8" and 5/8" oil resistant hose. You'll need about two feet of each. Should be about $6.00 total. I used Aeroquip FC662 hose from a local hose supply company.
