Old 04-03-2006, 02:26 PM   #1
wangan_cruiser
kouki man
wangan_cruiser's Avatar
Trader Rating: (36)
Feedback Score: 36 reviews
KA Water in the trunk and idle swinging
hello guys im pretty much new here in zilvia.net, im looking forward on tech support out here since i know zilvia.net is a big forum.
i have two problems to ask. i was wondering anyone had the same problem as mine. getting water in your trunk. anyone has an idea how water getting in?
next one is my idle is swinging back and forth from 900 to 600. sometimes it stays to 600 and then swing back to 900. anyone?
thanks for reading my thread
Old 04-03-2006, 02:42 PM   #2
punxva
punxva's Avatar
Trader Rating: (31)
Feedback Score: 31 reviews
ok, aparently since your very new, i'll fill u in, first of all every1 will tell you to search before you ask any question, because both of these have been covered about a million times. But im guess that you have a SE with a so called rear wing, it's probably leaking from that seeing as almost every1's does. Also the idle problem is the most common 240 problem. Try a tune up first, then go from there, also use the search button, it is your friend. BTW Welcome to Zilvia!!!
Slip Gypsies Blog
not sure if you realize this
Old 04-03-2006, 02:42 PM   #3
!Zar!
!Zar!'s Avatar
http://www.zilvia.net/f/showthread.php?t=103050
That's the fix for the water problem.
As for the idle.
Try to clean your airflow sensor.
Old 04-03-2006, 03:01 PM   #4
g6civcx
g6civcx's Avatar
Like they said above, the most popular places for leak are the taillamps and the spoiler.
Old 04-03-2006, 03:06 PM   #5
koukidough
koukidough's Avatar
koukidough is an unknown quantity at this point
i would say you should reseal your tail lamps that is the obvious leak.
1997 Nissan S14 SE Redtop SR20DET @12psi
1999 Honda Civic Hatch EK9 N/A b16a2 (SOLD)
koukidough is offline   Reply With Quote
