sileighty front end convo
hey does anyone know of a site where it would show how to do a complete s13 front end conversion on a 92 fast back? i just need to know how to wire everything. thanks
![]() Join Date: Apr 2004
It plugs right into your headlamp harness. No modifications needed. Does your Silvia lights have fogs in them?
I updated this thread with some pix for you: http://www.zilvia.net/f/showthread.p...&highlight=fog Last edited by g6civcx; 04-05-2006 at 11:37 PM.. |
![]() Join Date: Nov 2004
For the fogs. Either wire it to the headlight or just wire it to your spare harness into the brown and black wire. Then remove both headlight retract relays.
Or follow the tech. I found it easier to do without it. http://www.zilvia.net/f/showthread.php?t=85752
The wiring is really easy once you've figured it out. It's nice to have foglamps so may as well use them.
The parking light harness plugs right in. No modification needed. The turn signal harness also plugs right in, but you also have to tap it since there is an extra turn signal in the corner lamp of the Silvia. It's just 2 wires: one for signal power and one for ground. I'm sure you can figure it out if you look hard enough. |
