Old 04-15-2006, 12:19 PM   #1
miucus
miucus's Avatar
miucus has a reputation beyond reputemiucus has a reputation beyond reputemiucus has a reputation beyond reputemiucus has a reputation beyond reputemiucus has a reputation beyond reputemiucus has a reputation beyond reputemiucus has a reputation beyond reputemiucus has a reputation beyond reputemiucus has a reputation beyond reputemiucus has a reputation beyond reputemiucus has a reputation beyond repute
Right turn blinker, signals fast
i was driving normally then when i signalled to turn right, it was doing the blinking fast signalling. My left signal is still normal. Does anyone know how to re-wire it back or do something to put it back to normal?
thanks
miucus is offline   Reply With Quote
Old 04-15-2006, 12:24 PM   #2
Frenzy13
Frenzy13 is an unknown quantity at this point
Send a message via AIM to Frenzy13 Send a message via Yahoo to Frenzy13
thanks
Check the bulbs on the right side. Its a warning that says you have burnt one out. Just pull them out and look at them.
1992 240SX SE - Goodbye...
1997 240SX - At last I have one...
Frenzy13 is offline   Reply With Quote
Old 04-15-2006, 12:44 PM   #3
simz
simz has a little shameless behavior in the past
Send a message via AIM to simz
Ya what ^ said.
simz is offline   Reply With Quote
Old 04-15-2006, 03:37 PM   #4
g6civcx
g6civcx's Avatar
Broken bulb, or one that draws too little current.
Old 04-15-2006, 08:59 PM   #5
Irukandji
that happened to me when I disconnected my right turn signal and forgot to hook it back up. haha
Old 04-16-2006, 01:35 AM   #6
komedy
komedy is on the path to ruinkomedy is on the path to ruin
yup change the bulb and it will be back to normal
komedy is offline   Reply With Quote
Old 04-16-2006, 08:23 AM   #7
g6civcx
g6civcx's Avatar
Also as an FYI to those who may be having this problem after changing turn signals to JDM or LED, the OEM flasher relay detects resistance. JDM and LED lights draw really low currents. The stock relay thinks there is a broken bulb and flashes too quickly.
The solution is to get a Libertek flasher relay to replace the stock unit. It has an adjustable flash rate and doesn't vary flash rate if the current is too low. Costs about $40 from most motorbike online e-tailers.
