![]() Join Date: Apr 2004
New Features for Nissan Datascan
If you havent bought this for your ka24de or sr20det 240 yet here's more reasons why you should. Get a Conzult box and get this software!! This comes from Plms development in Australia and its only $25 AU dollars. New updates to v1.4.
Bug fixes and changes: Speed Trial result now in seconds (previously in 10ths of second) Minor cosmetic and label changes Bug fix for Air Flow right hand reading Improved Rom Download algorithm for better reliability (slow option only) New functions: Tyre size speed correction (Preferences window) Auto connect to ECU (Communication window) Compatibility with 96 model z32 ECU (Communication window) Active test for IACV valve User definable 0 to xxx Speed Trial Live register test – discovers parameters supported by the ECU as not every ECU supports them all, for example: Intake Air Temperature (Setup window) Map trace – a real time trace of a position on the map. This function is only available for z32 300zx cars at the moment. If the real time TP value address is known the function can be set up to work on any Consult I Nissan car. http://www.plmsdevelopments.com/consult_if.htm Also im curious if anyone has done a Carputer yet for their vehicles as I will be assembling one soon. |
Click on the link and you will receive answers. I've used it on ka's and it worked, just not the sohc because they do not support the consult protocol.
