Old 05-25-2006, 03:15 PM   #1
Indolent
Indolent's Avatar
Indolent has a spectacular aura aboutIndolent has a spectacular aura aboutIndolent has a spectacular aura aboutIndolent has a spectacular aura aboutIndolent has a spectacular aura aboutIndolent has a spectacular aura about
Send a message via AIM to Indolent
compression test out of car, motor cold, how much does it affect compression readings
before i slap in this motor, i'm going to compression test it, i read that it's best when the engine is fully warmed up, well i can't really do that but 'how' does it affect compression readings? like how off would it be or something if it were warmed up? basically i just want a better understanding why it is so.
Indolent is offline   Reply With Quote
Old 05-25-2006, 03:37 PM   #2
RightWheelDrive
RightWheelDrive is on a distinguished road
I did a cold compression test just last week. It is better to do a compression test when the engine is warmed up to operating temperature because the metal expands when it gets hot, which makes the gaps in the engine smaller, which in turn gives you better compression. You should still be getting good compression numbers when the engine is cold since the metal expansion will not make up for worn rings and such. I hope that helps, Good Luck.
RightWheelDrive is offline   Reply With Quote
Old 05-26-2006, 12:54 AM   #3
turbozxi
turbozxi is an unknown quantity at this point
You will get a lower reading, but aslong as the readings are similar between the cylinders you should be good.
turbozxi is offline   Reply With Quote
Old 05-28-2006, 05:43 PM   #4
mikesim
mikesim's Avatar
mikesim is an unknown quantity at this point
Send a message via MSN to mikesim
i did a test once when cold, it was almost 30psi lower across all four cylinders.
JDMOC||1989 Silvia K's
mikesim is offline   Reply With Quote
Old 05-28-2006, 08:46 PM   #5
formeRiceR
formeRiceR is an unknown quantity at this point
I read somewhere that what you can do is do a compression test cold and then you do one hot. The difference between the two figures tells you how worn your rings are ... or something like that....
"Street racers don't need girls." -Lonely Driver
Learning about cars one FLAME at a time ... (thanks to TNORD)
formeRiceR is offline   Reply With Quote
