Old 06-10-2006, 02:18 PM   #1
RalliartRsX
Trader Rating: (32)
RalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfection
Feedback Score: 32 reviews
Removing exhaust cat bolts
Well, I was in the process on installing my exhaust, and, as expeted, there is a hangup. The bolts which bolt the midpipe of the new catback to the cat seem to have been welded together. I kinda realized this and tried drenching it in wd-40 for about 4 days prior to working on it. Also, the bolt itself seems to have no threads as from heating and cooling, it seems to have warped the metal to the point of looking almost molten and rusted.
I already almost rounded one of the nuts with my impact wrench and the other is in too of an awkward position to use the impact. My next step of process is to just take it to midas or a muffler shop locally and just have em cut it off and drive back with only the cat. But, before I go ahead and do that, I wanted to see if you guys had any more ideas before this is all done.
Thanks.
RalliartRsX is offline   Reply With Quote
Old 06-10-2006, 07:18 PM   #2
NIK90s13
NIK90s13's Avatar
NIK90s13 is making a name for him/her selfNIK90s13 is making a name for him/her self
If you don't have a porch you can use, take it to a shop, they shouldn't charge much, I don't know what they charge in Jamaica. But That would be easyest. Where in Jamiaca are you?
NIK90s13 is offline   Reply With Quote
Old 06-10-2006, 08:26 PM   #3
RalliartRsX
Trader Rating: (32)
I am currently in the US right now. Was in JA for a while.
Actually, what I might just end up doing is taking it to a shop. Maybe easier. I will check prices monday morning. Thanks
Old 06-10-2006, 08:45 PM   #4
NIK90s13
NIK90s13's Avatar
Yea to cut a couple of bolts and yank the exaust out, they shouldn't charge much.
Old 06-10-2006, 09:04 PM   #5
radhaz
radhaz's Avatar
radhaz has much to be proud ofradhaz has much to be proud ofradhaz has much to be proud ofradhaz has much to be proud ofradhaz has much to be proud ofradhaz has much to be proud ofradhaz has much to be proud ofradhaz has much to be proud ofradhaz has much to be proud ofradhaz has much to be proud ofradhaz has much to be proud of
I imagine if you had one at your disposal you would have already used it but I ended up using a torch to heat my exhaust bolts to the point where they would break free. I had the same problem where they were virtually welded together, but after heating the nuts up to the point they were glowing I was able to take them off with very little resistance.
Need a 96 driver side window switch. Feel free to pm me with a price
radhaz is offline   Reply With Quote
Old 06-10-2006, 09:17 PM   #6
neilsan
neilsan is making his/her stupidity well-knownneilsan is making his/her stupidity well-knownneilsan is making his/her stupidity well-known
i drilled out the hardware and sawzalled the gasket out from in between the flanges.
neilsan is offline   Reply With Quote
Old 06-11-2006, 01:11 AM   #7
RalliartRsX
Trader Rating: (32)
I might end up using that torch idea as I happen to have one handy . I suppose its better to just go ahead and get a new cat too as well, but I ohh so wanted to bolt her up this weekend, grrrr!!!
We will see.
Thanks for all the help folks!!
