Old 05-25-2006, 04:49 PM   #1
buku_points
buku_points's Avatar
buku_points is close to perfectionbuku_points is close to perfectionbuku_points is close to perfectionbuku_points is close to perfectionbuku_points is close to perfectionbuku_points is close to perfectionbuku_points is close to perfectionbuku_points is close to perfectionbuku_points is close to perfectionbuku_points is close to perfectionbuku_points is close to perfection
SR denso iridium spark plugs
is anyone running the denso iridium spark plugs? are they better than the ngk iridium plugs? im running 12 lbs on a 95 sr20det with t28 bb turbo. ive already searched the forums and found nothing. any info would be thankful.
buku_points is offline   Reply With Quote
Old 05-25-2006, 07:43 PM   #2
Ragnarok043
Ragnarok043 is making a name for him/her selfRagnarok043 is making a name for him/her self
i think the Denso plugs have a smaller center electrode which means less voltage required to spark.
Ragnarok043 is offline   Reply With Quote
Old 05-25-2006, 10:46 PM   #3
dct223
dct223's Avatar
dct223 is just really nicedct223 is just really nicedct223 is just really nicedct223 is just really nicedct223 is just really nicedct223 is just really nicedct223 is just really nicedct223 is just really nice
Send a message via AIM to dct223
dont use denso.. unless you want to blow a good motor..
friend used densos on his S14 sr... not even full boosting an electrode broke into the #1 cylinder and yeah.. something so small blew the motor, scraped up the cylinder walls, dented the head where teh valves are and also bent a vlave.
another friend had them in his EF civic with a d16.. He thought it was weird how one sprark plug wire was always popping off, he removed the spark plug to find out that the whole thing electrode and the white part were moving up and down, and if he didnt catch it it would have eventually broken off and blow the motor...
ever since TWO people i know had problems with denos, never wanted to use them.
NGK-R FTW
Sfourteen
dct223 is offline   Reply With Quote
Old 05-25-2006, 10:57 PM   #4
mjjstang
mjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to behold
Send a message via AIM to mjjstang
yes ive heard horror stories with denso. im using ngk iridiums. Good stuff.
I was going to, but I can not think of a sig less than 75 characters.
mjjstang is offline   Reply With Quote
Old 05-25-2006, 11:02 PM   #5
Ricks15
Ricks15's Avatar
Ricks15 has much to be proud ofRicks15 has much to be proud ofRicks15 has much to be proud ofRicks15 has much to be proud ofRicks15 has much to be proud ofRicks15 has much to be proud ofRicks15 has much to be proud ofRicks15 has much to be proud ofRicks15 has much to be proud ofRicks15 has much to be proud ofRicks15 has much to be proud of
Nissan='s NGK
Ricks15 is offline   Reply With Quote
Old 05-25-2006, 11:44 PM   #6
carkid0007
carkid0007 can only hope to improve
So which NGk's do you reccommend ? I have the denso iridiums in now but havnt started the motor yet, just got it swapped, and if possible I won't use them if they are bad as you guys say.
carkid0007 is offline   Reply With Quote
Old 05-26-2006, 08:40 AM   #7
mjjstang
7 heat range gapped to 28 I believe. I had something like the brk7xxxxxxx but there is one out there that is pregapped to .28 i believe. the ones I had at first had to be gapped down to .28, but you dont want to gap iridiums, so try to find the one that is gapped right to begin with. I had a hell of a time trying to find them, but I think it was sparkplug.com.
found it. http://www.ngk.com/results_cross.asp...7EIX&x=47&y=13 they are gapped to .30 cheapest place to get them AFAIK.
Old 05-26-2006, 10:42 AM   #8
buku_points
i noticed that one coil kept popping off!!!!! i took those denso out right away!!!!! i went to use the ngk iridiums, but will it really make a diffenece? im running 12 lbs of boost, should i just buy the 92 sentra ser spark plugs or different ones?
Old 05-26-2006, 11:18 AM   #9
HyperTek
im rockin these regular plugs NGK PFR5ES as this tech article suggests, http://www.royalpurple.com/dragsport1/ds1p1.html
but yet to switch over to iridiums.
Keep it Classy
Old 05-26-2006, 12:03 PM   #10
spdfreek0o
spdfreek0o will become famous soon enoughspdfreek0o will become famous soon enoughspdfreek0o will become famous soon enough
Send a message via AIM to spdfreek0o
I've been running denso iridiums for awhile and had no problems. I even pulled them out last week and checked them, nothing was loose and they were all still gapped pretty close to the original specs.
spdfreek0o is offline   Reply With Quote
Old 05-26-2006, 12:23 PM   #11
dct223
dct223's Avatar
Yes its not like ALL DENSOS are going to be bad... you have to look at the big picture, if there are lots of people who have bad experiences with a product... the most logical thing is to find another product that is better...
but hey, if you like densos and are happy with them, no one is saying you HAVE to change them....
Sfourteen
Old 05-26-2006, 12:27 PM   #12
Ragnarok043
NGK-R FTW
by any chance do you know if they tried to gap them, with such a fine tip youre not suppose to gap Iridiums and use them straight out of the box.
Old 05-26-2006, 12:42 PM   #13
dct223
dct223's Avatar
not sure, but if they come pregapped, then im pretty sure they would not try to "regap" them
also what you wrote is kinda conflicting... im assuming you were trying to say that "your supposed to use them straight out of the box"
Sfourteen
Old 05-26-2006, 05:45 PM   #14
mothon
mothon's Avatar
mothon has a reputation beyond reputemothon has a reputation beyond reputemothon has a reputation beyond reputemothon has a reputation beyond reputemothon has a reputation beyond reputemothon has a reputation beyond reputemothon has a reputation beyond reputemothon has a reputation beyond reputemothon has a reputation beyond reputemothon has a reputation beyond reputemothon has a reputation beyond repute
Always check the gap on any plug before you install them. Gap can change from shipping and handling.
mothon is offline   Reply With Quote
Old 05-26-2006, 06:55 PM   #15
buku_points
i bought the ngk iridium's their were originally gaped to .45 so i regaped them to .30
Old 05-26-2006, 07:45 PM   #16
mjjstang
the link I showed you was for the exact ones that I use, like the guy above me, he bought the ones that part number ends in 11 which is the 45, he gapped his electrode way too much and now is running the risk of it failing IE breaking loose in the chamber and causing catastrophic engine failure, so if you want good Iridiums, (although many people swear by copper) I however noticed a HUGE in terms of "its just a spark plug what kind of difference can it make" difference, night and day engine performance difference. I got the .30 gapped ones and no need to regap them, heat range 7 for srturbo.
Old 05-27-2006, 06:43 PM   #17
buku_points
yea i noticed a real big difference in power altough i did re-gap them ill end up gettig new ones soon, that part number on the website you posted, can you take that number to kregan and theyll find it?
Old 05-27-2006, 10:27 PM   #18
mjjstang
no kregan around here, so i donno, maybe, I know pepboys, autozone, murrays and all the other places I tried, looked at me like I was an iditot and didnt belong in their store, then proceeded to tell me their bosh +33 was so much better with 33 differnt electrode straps. so i said fuckit and got from sparkplug.com.
Old 05-28-2006, 11:44 AM   #19
buku_points
ahh oh well thanks for the info though!
Old 06-01-2006, 05:17 AM   #20
Highboost180SX
Highboost180SX is on a distinguished road
what are the correct denso and NGK part numbers for the "one step colder" heat range?
Highboost180SX is offline   Reply With Quote
Old 06-01-2006, 05:59 AM   #21
Cashizslick
Cashizslick can only hope to improve
I use BKR6E's gapped to a .30
Cashizslick is offline   Reply With Quote
Old 06-01-2006, 06:16 AM   #22
mjjstang
do you use the bkr6e with a turbo?
