Old 06-06-2006, 09:12 PM   #1
bluuuurr
bluuuurr's Avatar
bluuuurr is an unknown quantity at this point
removing EGR
After researching I've decided that I don't need my EGR Valve (which has been flashing CEL's in my face and occasionally sputtering my motor). Being that I live in a non-emmissions area I think my best plan is to just rid myself of it.
Question 1. If I was to remove the valve altogether would I still get a CEL?
Question 2. Does anyone have a DIY guide or some helpful pictures to assist me?
thanks in advance!!
bluuuurr is offline   Reply With Quote
Old 06-06-2006, 09:24 PM   #2
projectRDM
projectRDM's Avatar
1) Yes.
2) Remove. Block off. Drive.
Old 06-07-2006, 11:51 AM   #3
Lurkable
Lurkable will become famous soon enoughLurkable will become famous soon enoughLurkable will become famous soon enoughLurkable will become famous soon enough
Send a message via AIM to Lurkable
There's a fuse you can solder into a sensor that eliminates the CEL after removing the EGR. Still, some people remove the EGR and don't even get the CEL after that. Search freshalloy.
Rim: n. The circular outer part of a wheel, furthest from the axle.
Rim: n. A circular metal structure around which a wheel tire is fitted.
Wheel: n. A solid disk or a rigid circular ring connected by spokes to a hub, designed to turn around an axle passed through the center.
Lurkable is offline   Reply With Quote
Old 06-07-2006, 01:12 PM   #4
projectRDM
projectRDM's Avatar
Resistor, not fuse. Check your info before posting please.
