Old 05-23-2006, 06:46 PM   #1
P4rD0nM3
P4rD0nM3 is a glorious beacon of lightP4rD0nM3 is a glorious beacon of lightP4rD0nM3 is a glorious beacon of lightP4rD0nM3 is a glorious beacon of lightP4rD0nM3 is a glorious beacon of lightP4rD0nM3 is a glorious beacon of lightP4rD0nM3 is a glorious beacon of lightP4rD0nM3 is a glorious beacon of lightP4rD0nM3 is a glorious beacon of lightP4rD0nM3 is a glorious beacon of lightP4rD0nM3 is a glorious beacon of light
TUNE UP: Am I missing something?
1. Replaced O2 sensor
2. Replaced Air Filter
3. Replaced Fuel Filter with 300zx
4. Replaced Oil Filter with OEM 240SX Filter (Replaced oil too)
5. Replaced Spark Plugs with NGK Iridium Spark Plugs
6. Replaced Spark Plug wires with NGK Spark 7mm Plug Wires
7. Replaced Distributor cap with a new one (Hitachi)
8. Replaced Rotor cap with a new one (Hitachi)
9. Replaced any leaking injectors with used but non-leaking ones
* After this, I poured seafoam in my almost empty (And I mean ALMOST EMPTY) gas tank. There's two more places that you should pour it but hehe I dunno how to properly do it, Kinematics showed me how but I tend to forget stuff).
* Then after doing the seafoam treatment, I filled the gas tank half way and waited until it's almost empty again and poured some Fuel System cleaner.
Anything else that I forgot to do?
P4rD0nM3 is offline   Reply With Quote
Old 05-23-2006, 06:50 PM   #2
tre
tre's Avatar
tre will become famous soon enoughtre will become famous soon enoughtre will become famous soon enoughtre will become famous soon enoughtre will become famous soon enough
Why not do a coolant flush and run straight water (if you do not have to worry bout freezing conditions) Cars tend to keep 20degrees cooler with straight water vs 50/50 mix.
I didn't buy an Audi because it is a Great Car, but for more of a reason to be an asshole.
tre is offline   Reply With Quote
Old 05-23-2006, 06:51 PM   #3
tre
tre's Avatar
BTW are those spacers for a set of 4?
Old 05-23-2006, 06:51 PM   #4
kouki_s14
kouki_s14's Avatar
kouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfection
Send a message via AIM to kouki_s14
after seafoam, you gotta replace the plugs again
what about tranny and diff oil?
belts check
coolant flush
brake/clutch bleed
list goes on, but thats the main ones i can think of for now
kouki_s14 is offline   Reply With Quote
Old 05-23-2006, 06:53 PM   #5
tre
tre's Avatar
Hell if you're at it like that. Why not replace your clutch fluid and brake fluid, with higher quality fluid.
Bleeding brakes will take forever. but is fun
Brakes/Rotors (if you haven't replaced recently?)
lol many things you can do :P check all your fuses too. I've done that and pulled out a few popped ones.
Old 05-23-2006, 06:54 PM   #6
sw20>>s14
sw20>>s14's Avatar
i usually do 1/3 in a near empty gas tank, 1/3 in the crankcase (followed by an oil change), and 1/3 to the throttle body via the vacuum hose...
you may as well do the coolant and tranny fluid if you are due...
sw20>>s14 is offline   Reply With Quote
Old 05-23-2006, 06:56 PM   #7
P4rD0nM3
Wait so I have to replace my spark plugs again? T_T.
And yes it's a set for $190.
I forgot to mention I already did the tranny and diff + clutch bleed. Not brake though. T_T.
I have to have an anti-freeze, I'm in CO.
Old 05-23-2006, 06:57 PM   #8
kouki_s14
kouki_s14's Avatar
yes seafoam ruins sparkplugs
you're supposed to seafoam before you change the plugs
Old 05-23-2006, 07:00 PM   #9
MELLO*SOS
LAID OUT
MELLO*SOS's Avatar
MELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfection
Are you asking because you did all this and the car still has problems? Or are you just looking for more things to do... Sounds like you got most of the major things taken care of. Here are few other miscellaneous parts to check:
Clean the MAF
Clean IACV
Check the ECU for codes while you're at it...
Change trans gear oil
If you have an LSD, change gear oil there as well
Check PS fluid level
Check Brake fluid level
Check clutch fluid level
Inspect cooling system: upper & lower radiator hoses are in good condition, flush/bleed coolant and water, check/replace thermostat and check/replace pressure cap.
edit: 6 replies posted in the time it took to post this one... sry for some duplicate ideas
MELLO*SOS is offline   Reply With Quote
Old 05-23-2006, 07:06 PM   #10
tre
tre's Avatar
I have to have a anti-freeze, I'm in CO.
so you hav ea full set of 35mm spacers and 15mm spacers? o.0
Old 05-23-2006, 07:08 PM   #11
2iv0 sx
2iv0 sx's Avatar
2iv0 sx has a reputation beyond repute2iv0 sx has a reputation beyond repute2iv0 sx has a reputation beyond repute2iv0 sx has a reputation beyond repute2iv0 sx has a reputation beyond repute2iv0 sx has a reputation beyond repute2iv0 sx has a reputation beyond repute2iv0 sx has a reputation beyond repute2iv0 sx has a reputation beyond repute2iv0 sx has a reputation beyond repute2iv0 sx has a reputation beyond repute
^Sucks being pinked huh hehe
Thanks for reminding me and also for the list of things. +1
Looks like im going to be busy this summer. Trying to figure out what the hell is causing this lag i have on my KA.
2iv0 sx is offline   Reply With Quote
Old 05-23-2006, 07:13 PM   #12
tre
tre's Avatar
What kind of lag? Like split secong reaction time lag? Then power on?
But anyways. Yes being pinked sucks. And for the stupidest reason ever. And its amazing how being a premium member buys you more slack.
Old 05-23-2006, 07:20 PM   #13
P4rD0nM3
No the car runs great. It's just that it's summer and since I have no summer classes to attend to, I'm finding a 2nd job to fill my school time...and I'm doing some maintenance on my 240. I've overlooked some stuff that you guys listed. I'll be sure to do those stuff too. Some of them I didn't even do last year or even 2 years ago.
Old 05-23-2006, 07:22 PM   #14
P4rD0nM3
Oh shoot tre, forgot about you.
It's a pair of 15mm and a pair of 35mm.
kouki_s14, good thing I have some extra...I'll change them right now. Brb.
Old 05-23-2006, 07:22 PM   #15
tre
tre's Avatar
how bout a new battery? lol :P
Old 05-23-2006, 07:29 PM   #16
P4rD0nM3
I did that last December. I'm lookin' at the battery being sold at PDM Racing. It's the Genesis Compact Battery. That way I don't have to relocate it when I do the FMIC piping.
Old 06-02-2006, 06:17 PM   #17
P4rD0nM3
Hmm, I don't see any injectors leaking but it throws code 45...is it my fuel rail?
Old 06-02-2006, 06:29 PM   #18
dct223
dct223's Avatar
dct223 is just really nicedct223 is just really nicedct223 is just really nicedct223 is just really nicedct223 is just really nicedct223 is just really nicedct223 is just really nicedct223 is just really nice
Send a message via AIM to dct223
new accessory belts, maybe change coolent temp sensor
Sfourteen
dct223 is offline   Reply With Quote
Old 06-02-2006, 06:57 PM   #19
P4rD0nM3
45 is leaky injector though...you think it's something else? ECU is saying 45.
Old 06-02-2006, 07:07 PM   #20
dct223
dct223's Avatar
i wasnt saying how to fix code 45.. i was suggesting other things for a tune up..
Sfourteen
Old 06-02-2006, 07:13 PM   #21
P4rD0nM3
Oh. Hehe. It just lit up a couple of hours ago...I put it in mode iv to reset it since I didn't see any leaks...but it still went on. I"m gonna drive it for awhile then replace the remaining three injectors that I didn't replace.
Old 06-02-2006, 07:15 PM   #22
P4rD0nM3
Yep, I did that...no smoke went out though and I put around 2/3s on each normal opening you pour the seafoam. Does it ruin injectors too? It's supposed to clean them right? T_T
Old 06-03-2006, 03:09 AM   #23
mrmephistopheles
mrmephistopheles's Avatar
PCV valve too.
It's right on top of the intake mani on KA24E's so REALLY easy to change.
Originally Posted by PHLIP
Old 06-03-2006, 02:15 PM   #24
P4rD0nM3
Thanks mrmephistopheles. I found the culprit and it's in the same place the last injector was leakin' at...I dunno why it's hte only one who kept' on leaking. Is it the fuel rail now? Or should I still try my last used (Non-leaking) injector and try to see if it leaks again...?
Old 06-04-2006, 12:21 PM   #25
stinky_180
stinky_180's Avatar
Trader Rating: (26)
Feedback Score: 26 reviews
try replacing the o-rings with new ones.
WheelsDirty
Old 06-04-2006, 01:19 PM   #26
finalforce
finalforce is on a distinguished road
Good thread for 240 tuners
finalforce is offline   Reply With Quote
Old 06-04-2006, 09:25 PM   #27
Akiros
Akiros's Avatar
Akiros is close to perfectionAkiros is close to perfectionAkiros is close to perfectionAkiros is close to perfectionAkiros is close to perfectionAkiros is close to perfectionAkiros is close to perfectionAkiros is close to perfectionAkiros is close to perfectionAkiros is close to perfectionAkiros is close to perfection
Send a message via AIM to Akiros
Archive/FAQ maybe?
Akiros is offline   Reply With Quote
Old 06-04-2006, 09:46 PM   #28
m0rex
m0rex's Avatar
m0rex is on a distinguished road
Clean the throttle body good with some berryman b12.
m0rex is offline   Reply With Quote
Old 06-04-2006, 10:35 PM   #29
stinky_180
stinky_180's Avatar
Trader Rating: (26)
rewire all engine grounding points
WheelsDirty
Old 06-04-2006, 11:00 PM   #30
kandyflip445
kandyflip445's Avatar
Interior fasteners? You could chase down all the little loose stuff and put felt in where there are squeks and noises. It's very worthwhile. The PCV is VERY important. You could clean up the engine bay if it isn't clean already that way you can spot if you have any leaks easy. Windshield wipers. Vacuum hoses if they've never been touched.
My 240 vBgarage
