Old 09-14-2006, 12:39 PM   #1
EndLeSS8
EndLeSS8's Avatar
EndLeSS8 will become famous soon enoughEndLeSS8 will become famous soon enoughEndLeSS8 will become famous soon enough
Are strut bars necessary for a car with coilovers?
Would a set of strut bars make a big difference in handling for a car that has coilovers?
Street car, daily driven.
Searched, couldn't find an answer on this.
My setup:
Tein HE's, RUCAs, SPL Tension rods and ends, Front and rear OEM sways, running on Advan Neovas
Thanks in advance.
268generation.com
-United for His Renown-
EndLeSS8 is offline   Reply With Quote
Old 09-14-2006, 02:26 PM   #2
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
Feedback Score: 48 reviews
Think about it
one is a chassis upgrade and the other one suspension.
In either case, this thread shouldn't exist. Simply borrow a friend's strut bar for a few minutes
and find out for yourself if it's worth it or not.
Old 09-14-2006, 03:40 PM   #3
EndLeSS8
EndLeSS8's Avatar
I don't personally know anyone with an S14 around here.
268generation.com
Old 09-14-2006, 03:45 PM   #4
Creizai
Creizai has a spectacular aura aboutCreizai has a spectacular aura aboutCreizai has a spectacular aura aboutCreizai has a spectacular aura aboutCreizai has a spectacular aura aboutCreizai has a spectacular aura about
It would be one of the last things you should do the money / performance ratio is very low. Most people buy them for the "Bling" look. Take those 2 Name brand strut bars your going to buy (200$ + Each) thats 400$, thats enough for sway bars, or a 4 point cage (which will help ALOT more than strut bars).
I'm simply talking about 240sx... i've seen on other cars front ones help a shit ton.
I'd say use your money for Tanabe Rear Sway if your into drifting, if your for AutoX get Front and Rear.
Creizai is offline   Reply With Quote
Old 09-14-2006, 04:00 PM   #5
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
hmmm.. it was one of my first upgrades with my first hatch and it made a huge difference.
I would think that the benefit would be less on an S14 since it's significantly stiffer a chassis than the S13 specially since
you have a pretty good set up as is.
A good alignment and corner balance would be my recommendation if you haven't already done that.
Get a set of cheap strut bars off ebay and call it a day, same performance as the more expensive branded stuff.
Old 09-14-2006, 04:26 PM   #6
mistaanime
mistaanime's Avatar
mistaanime is making a name for him/her selfmistaanime is making a name for him/her self
Send a message via AIM to mistaanime
all it does is it stiffens your chassis...its good probably later on down the line..if you decide to get a road cage..you mite not even need strut bars..
-Cherry Red 91 Silfourty-
mistaanime is offline   Reply With Quote
Old 09-14-2006, 05:36 PM   #7
EndLeSS8
EndLeSS8's Avatar
Ok, thanks for the info, that's what I wanted to know.
I don't plan on caging the car, and the car had alignment done 2 weeks ago, so I think it should be fine for now. If I do, I'll opt for a cheaper version later on.
Thanks for the heads up.
268generation.com
Old 09-14-2006, 06:16 PM   #8
DJPimpFlex
DJPimpFlex's Avatar
Trader Rating: (115)
DJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond repute
Feedback Score: 115 reviews
Send a message via AIM to DJPimpFlex Send a message via MSN to DJPimpFlex
Well you also need to corner weight your car to make full use of that expensive rubber. Strut tower bars do a lot more with coilovers than on stock suspension. Think about it, the springs are stiffer, so they transfer more enegry into the car, leading to more flexing of the strut towers. I have CP racing front and rear. The front one attaches to the firewall as well and it made a huge different even on stock suspension. Better turn in and more crisp steering feel. I didnt notice any imporvement with the rear one, but I put it on anyway.
DJPimpFlex is offline   Reply With Quote
Old 09-14-2006, 08:01 PM   #9
kuramaya
kuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfection
FSTB + RSTB = Great handling on the Touge
ZEROYON WEBSITE IS HOMO
NEW SITE: blacklinux.com/innersanctum/index.php
kuramaya is offline   Reply With Quote
Old 09-14-2006, 08:45 PM   #10
cgguy
cgguy's Avatar
cgguy is on a distinguished road
If you do wind up buying strut bars get a good one piece bar or even better a 3 point bar that attatches to the firewall. I have a rear 3 piece Megan bar that's so damn flimsy there's no way it does anything for structural rigidity. They look cool and that's about it.
cgguy is offline   Reply With Quote
Old 09-14-2006, 09:31 PM   #11
projectRDM
projectRDM's Avatar
Tomei is the only company that makes a quality 3point bar. Everything else anchors to the wiper cowl, which in itself is about as thick as notebook paper. It'd be better off glued on with a tube Elmer's.
Old 09-15-2006, 05:33 PM   #12
lonedrifter
lonedrifter is an unknown quantity at this point
s13
My setup:
Thanks in advance.
get them ! they really do help,
lonedrifter is offline   Reply With Quote
Old 09-15-2006, 05:51 PM   #13
brainfood
brainfood's Avatar
Trader Rating: (18)
brainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond reputebrainfood has a reputation beyond repute
Feedback Score: 18 reviews
I have never ran them, Started out just upgrading things that I felt were holding me back or to make the car better in an area that I thought it needed improvement. And never felt the chassis was flexing too much esp. not that the strut bars would help too much anyway. Never felt like spending the money is all. On s14 chassis the rear's seem pretty useless unless its a triangulated one, but if you have a cage not really worth it. I have seen some triangulated fronts that I would rock but they should do a lot more than the single bar.
Bryan Rogers
http://www.seriousbadass.com
brainfood is offline   Reply With Quote
