Old 08-04-2006, 02:35 AM   #1
dylokjai
dylokjai is an unknown quantity at this point
gas leak ?
i got a very bad gas leak from the rear of the car. It only leak when key is ON and when key is on OFF it stops..where to check first? fuel pump area? do i have to remove my gas tank?
dylokjai is offline   Reply With Quote
Old 08-04-2006, 03:09 AM   #2
sw20>>s14
sw20>>s14's Avatar
when the key is on the ON position, the fuel pump is on...when its on the OFF postion, the fuel pump stops...check the fuel lines for fractures and such...
sw20>>s14 is offline   Reply With Quote
Old 08-04-2006, 03:41 AM   #3
reccakun08
reccakun08's Avatar
reccakun08 is a jewel in the roughreccakun08 is a jewel in the roughreccakun08 is a jewel in the roughreccakun08 is a jewel in the roughreccakun08 is a jewel in the roughreccakun08 is a jewel in the roughreccakun08 is a jewel in the rough
+1 for fuel line
reccakun08 is offline   Reply With Quote
Old 08-04-2006, 05:28 AM   #4
ej2civic
ej2civic is a jewel in the roughej2civic is a jewel in the roughej2civic is a jewel in the roughej2civic is a jewel in the roughej2civic is a jewel in the roughej2civic is a jewel in the roughej2civic is a jewel in the rough
if it is an s13/s14 just pull up the rear carpet and you sould have access to fuel pump. you do not have to remove tank.
ej2civic is offline   Reply With Quote
Old 08-04-2006, 05:49 AM   #5
g6civcx
g6civcx's Avatar
Check the fuel pump gasket. Those usually break and gas fumes leak into the car.
