Old 08-09-2006, 12:55 AM   #1
driftkid316
driftkid316 is making a name for him/her selfdriftkid316 is making a name for him/her self
Send a message via AIM to driftkid316
Why do I keep overheating? even with tuarus fan
i put a whole jug of 50/50 premixed antifreeze coolant in and filled the rest with water. have a tuarus fan on high speed at all times. but the damn thing still overheats, not so much on the freeway cause so much air. but when city driving and obviously parked, it over heats pretty fast. i know the guage isnt messed up cause when i pop the hood i can hear it boiling. the radiator seems to be ok, not too much rust. what could it be?
driftkid316 is offline   Reply With Quote
Old 08-09-2006, 01:43 AM   #2
Xren17
Xren17 is an unknown quantity at this point
Did you jack it up and bleed it through the bleeder valve? I had the same problem and it was fix after bleeding it.
Xren17 is offline   Reply With Quote
Old 08-09-2006, 01:57 AM   #3
driftkid316
im sorry, i dont know how to bleed it. how do i go about doing that? btw, i have a 90 s13 sohc
Old 08-09-2006, 02:09 AM   #4
daryl337
daryl337's Avatar
daryl337 has a spectacular aura aboutdaryl337 has a spectacular aura aboutdaryl337 has a spectacular aura aboutdaryl337 has a spectacular aura aboutdaryl337 has a spectacular aura aboutdaryl337 has a spectacular aura about
Send a message via MSN to daryl337
There are many things that can cause an over-heating problem... but just by saying that your fan actually turns on eliminates about 50% of them.
Try a new thermostat... 80% of the time that is the problem. If it isnt that, look for soft hoses, as well as flush your entire system a few times to make sure that there isnt rust in the BLOCK that is blocking anything. If it is not that, then look into the water pump cavitating.
BTW.. bleeder valves USUALLY are on the intake manifold or the head (forgot where it is on the ka24e)... In any situation, it is going to be up high.
daryl337 is offline   Reply With Quote
Old 08-09-2006, 02:24 AM   #5
blu808
blu808's Avatar
blu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfection
Send a message via AIM to blu808
What most peeps dont realize is that when the rad cap is off, and you fill it up, it is just filling up the rad. One way to think of it is if your thermostat is a plug in you radiator. and when it finally opens after about 15 mins of idle, then it starts circulating coolant through the engine water jackets. I would recc that you start the motor completely cold. with the rad cap off, then keep feeding it water for 30 mins. after letting it run for 15 mins the thermo will open and suck up the water. Just keep feeding it, until there are no more air bubbles. Air is the main cause of overheating. Just think of air as your bin lauden. Get it all out. then before it starts gushing out cap it.
make sure before this you have your coolant res filled. that way it wont suck up any bin lauden air.
If that doesnt work. you may try changing your t stat. then your water pump. if that fails. do a leak down test and see if you have a blown cyl, or h gask.
Poo FTW.
blu808 is offline   Reply With Quote
Old 08-09-2006, 02:24 AM   #6
driftkid316
if it is the thermostat, wouldnt it just make my guage read wrong and the car would still not really overheat?
Old 08-09-2006, 02:26 AM   #7
blu808
blu808's Avatar
no. your coolant temp sensor is in the water neck after the t stat. so if it failed it wouldnt even be close.
KA, sr, rb, vg same stuff.
Old 08-09-2006, 02:48 AM   #8
daryl337
daryl337's Avatar
Well, basically think of it like this. Your water pump is pumping away like the little pump it is... and from there... the water can go to two places... 1) it goes to your radiator where it is cooled... or two... it goes out your coolant bypass line and recirculates throughout the motor. When the thermostat is closed, no cool water comes from your radiator... and to prevent any pressure from building up in the radiator... the water is recirculated in the block. As the recirculated water heats up.. the thermostat opens up.. and lets the cooled water come in.
Now... what does this mean for you? A sticky thermostat keeps your radiator from giving you cool water. =D But like I said.. also check for collapsing hoses... and do a good flush just to make sure you are getting proper flow.
