Old 08-08-2006, 07:34 PM   #1
PhR0Z3N_PhL4M3
PhR0Z3N_PhL4M3 is an unknown quantity at this point
Motor mount removal and installation?
How the heck do you get the old motor mounts off? I've checked the FSM and couldnt find anything bout it, thanks for your help
andrew
PhR0Z3N_PhL4M3 is offline   Reply With Quote
Old 08-08-2006, 07:46 PM   #2
mmdb
mmdb's Avatar
mmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymore
simply put:
1. jack up the front of the car
2. loosen the subframe bolts (do no drop the subframe)
3. unscrew motor mount
4. remove/replace
for more indepth explanation do a search.
mmdb is offline   Reply With Quote
Old 08-08-2006, 07:52 PM   #3
boosteds13
boosteds13's Avatar
boosteds13 is just really niceboosteds13 is just really niceboosteds13 is just really niceboosteds13 is just really niceboosteds13 is just really niceboosteds13 is just really niceboosteds13 is just really niceboosteds13 is just really nice
Originally Posted by mmdb
simply put:
4. remove/replace
Provided they aren't stuck on there.
We had to battle with mine for over 5 hours just to get the driver's side mount off the crossmember. The nut ended up rounding off. We used a hacksaw, torch, drill, angle grinder, prybar, and one of those nuts that has the reverse threaded teeth.
"A CA? WTF is that? You shoulda got an SR yo."
View my vBPicGallery!
boosteds13 is offline   Reply With Quote
Old 08-08-2006, 08:09 PM   #4
g6civcx
g6civcx's Avatar
The mounting nuts are 14mm. The heat shield nut is 12mm. It's best to use 6-point deep well sockets. 6-point grips better than 12 without stripping.
Remove both front wheels and put the front end on jackstands. It will help you with clearance.
Spray PB Blaster liberally on the nuts and let it soak overnight. Tap lightly with a hammer to induce vibration and let the penetrant soak in.
The nut on the bottom can be access with a 12" extension. I used my 6" extension and both of my 3" extensions.
If you have problems, use a breaker bar and gently work it.
The 12mm nut won't be a problem. Just use an extension and put a breaker bar on the ratchet.
The top 14mm nut may be a problem. You'll need to use a wrench since the bracket won't allow you to use a ratchet. It's not bad though.
A trick you can use is slide your 14mm wrench on, and then use a bigger wrench as a cheater bar and slip it over the open end of the wrench. Play with it and you'll know the orientation.
Big tip for you. If you're using Nismo mounts, the studs on them are slightly longer than stock, maybe 1/2" or so. I wasn't able to lift the motor high enough so I removed the bracket on the motor. The bracket is held on by 4 14mm bolts. I was then able to slip the mount in and bolt the bracket back on to the motor. You can see this in the pictures in the link.
I used the bellhousing to lift the motor. The link uses pieces of wood on the a/c and alternator brackets. Others use different points, but I prefer the bellhousing.
Just take your time. It's best to do the exhaust side the turbo is out. You can't even see it with the motor in. On the intake side, it helps if you remove the oil filter and the intake manifold support bracket(s).
http://importnut.net/nismomm.htm
Old 08-08-2006, 08:24 PM   #5
TipStylez
TipStylez will become famous soon enoughTipStylez will become famous soon enoughTipStylez will become famous soon enoughTipStylez will become famous soon enoughTipStylez will become famous soon enough
^Good info, will be using this in a bit.
Thanks
-Q
TipStylez is offline   Reply With Quote
Old 08-08-2006, 08:40 PM   #6
PhR0Z3N_PhL4M3
Ya, problem is they are stuck on like a mofo, like boosteds13... I rounded the nut off and am using a metwrench to try and get it loose, it grabs hold, but wont budge, wasnt sure if the nuts were special or not. thanks tho
Old 08-09-2006, 05:49 AM   #7
g6civcx
g6civcx's Avatar
6 point heads on your socket/wrench and a breaker bar in conjunction with PB Blaster.
Old 08-09-2006, 11:05 AM   #8
PhR0Z3N_PhL4M3
ya, would work, but there is no room for a cheater pipe, and i've been spraying the snit outa it with liquid wrench... still no go
Old 08-09-2006, 11:47 AM   #9
g6civcx
g6civcx's Avatar
Try the big wrench on the little wrench trick I said above. Works when a big pipe doesn't fit.
Old 08-09-2006, 11:49 AM   #10
g6civcx
g6civcx's Avatar
Use the big wrench on little wrench trick.
