Ghost of Zilvia past
![]() Join Date: Sep 2003
KA24DE randomly dies and then starts back up.
I bought a 90 fastback with a twincam, and it ran fine for the first few days, but now it's wierd. I can be driving down the street or freeway, and the engine will randomly cut out completly, either just enough to make it stumble, or long enough for me to have to pull over and stop on the side of the freeway. But it will always kick back in. This is my third S13, but my first KA (I bought all my others with blown motors and swapped them) so if anyone could point me in the direction of what I should start looking at, that would help.
![]() Join Date: Feb 2005
distributor going out? fuel filter clogging? will the car shut off and then after it cools down start up like nothing's wrong?
pulling outta the game: http://www.zilvia.net/f/showthread.p...wpost&t=119867 parting out, just let me know. |
It'll start up instantly after shutting off whether it's hot or cold. All afternoon today it ran fine.
One thing though, the air filter keeps getting dirty on the "clean side" with soot. |
![]() Join Date: Mar 2004
Preach RitZ ! ! !
Just sounds like there might be corrosion on the terminal(s) it'll probably be most on the positive, if the car was not taken care of then on both. but handle the simpltons first. Check all connections make sure nothing is moving loosely.
"GHOST" |
Thanks guys! Although when the engine cuts out, nothing else does. The gauges and lights still work... I'll go over everything tonight anyways.
![]() Join Date: Mar 2005
When I had similar symptoms it was the coolant temp sensor
The one up top near the upper radiator hose on the block
![]() A SPEC PRODUCTS CORP AME Wheels, Advan, ARC, Gram Lights, Nardi, Personal, Recaro, Works Bell, Work Wheels, Volk Racing, 5Zigen, & more! 626.618.1100 x 103 / aim: aspectuan ![]() ![]() ![]() |
you know that may be it.... I know the temp gauge is supposed to read in one of 3 settings, cold, normal, hot, but mine will read cold, just above cold, and 2 other temps in addition to normal. I'll defineatly pick one up, wow, in addition to replacing my doors, fenders, and taillights, I've got my work cut out for me this weekend...
also check egr....carbon buildup (soot) could be the egr choking your car/ somehow backfiring it into the airfilter?
There had been an aftermarket air/fuel controller installed. I removed it and it has been fine since. Looks like the wiring was coming loose at one spot.
