Old 09-10-2006, 05:22 AM   #1
miklos
miklos's Avatar
miklos has made poor choicesmiklos has made poor choicesmiklos has made poor choicesmiklos has made poor choicesmiklos has made poor choicesmiklos has made poor choicesmiklos has made poor choices
Adding guages to 1990 240sx
I want to add an oil pressure guage. Where on a S13 KA24 could I do this?
And where would be a good place to tap and Ammeter into the main line?
miklos is offline   Reply With Quote
Old 09-10-2006, 07:08 AM   #2
Gutling
Gutling is an unknown quantity at this point
they sell sandwich plates that go between the oil filter and block, usually have two fittings on them for adding oil temp/pressure etc.
Gutling is offline   Reply With Quote
Old 09-10-2006, 07:18 AM   #3
S14DB
AFC #1
S14DB's Avatar
T the stock Oil pressure sender.
I have no clue what a Ammeter is.
Old 09-10-2006, 08:46 AM   #4
projectRDM
projectRDM's Avatar
Better yet, remove the stock oil pressure switch completely and replace it with a new one.
Old 09-10-2006, 08:51 AM   #5
Gutling
lol i had to re read it to get it too. i think he meant "a meter"
Old 09-10-2006, 04:15 PM   #6
punxva
punxva's Avatar
Trader Rating: (31)
Feedback Score: 31 reviews
replace the stock one with the autometer fitting, and run a 1/8 NPT grease gun line to your shock tower or somewhere and put the gauge's sender unit, and bada bing, now the logic behind this is the movement is known to crack the fittings when the autometer unit is connected straight to the block
Slip Gypsies Blog
not sure if you realize this
Old 09-11-2006, 03:41 AM   #7
miklos
miklos's Avatar
Ammeter is what they call an Amp Meter.
Old 09-11-2006, 03:55 AM   #8
Sil-Abc
Sil-Abc's Avatar
Sil-Abc is close to perfectionSil-Abc is close to perfectionSil-Abc is close to perfectionSil-Abc is close to perfectionSil-Abc is close to perfectionSil-Abc is close to perfectionSil-Abc is close to perfectionSil-Abc is close to perfectionSil-Abc is close to perfectionSil-Abc is close to perfectionSil-Abc is close to perfection
Send a message via AIM to Sil-Abc
explain to me why do u need to know the amps in the oil?
IM JON WAYNE ESQ.... bitch
Sil-Abc is offline   Reply With Quote
Old 09-11-2006, 07:50 AM   #9
projectRDM
projectRDM's Avatar
Geez guys, read much?
The kid wants to install gauges, plural. Oil pressure AND an ammeter. Of course, a voltmeter would be a better option, ammeters are rarely used anymore since the battery's amperage isn't what you want to know. A voltmeter would tie into any main ignition wire, from the column to the ECU.
Old 09-11-2006, 08:20 AM   #10
punxva
punxva's Avatar
Trader Rating: (31)
haha reading and comprehension FTW, hope my idea helped.
Slip Gypsies Blog
Old 09-11-2006, 10:18 AM   #11
Sil-Abc
Sil-Abc's Avatar
hahaha sleep deprivation for the lose.
Old 09-11-2006, 03:28 PM   #12
miklos
miklos's Avatar
Guages
I had a camaro and ran the main electrical wire through the amp meter.
I"m also adding a Vacuum guage.
Would the oil temp guage tie in with the pressure guage? Sounds like a stupid question but I want to make sure.
Old 09-12-2006, 01:40 AM   #13
bleachcola
bleachcola's Avatar
bleachcola is an unknown quantity at this point
no it wouldnt
bleachcola is offline   Reply With Quote
Old 09-12-2006, 03:23 AM   #14
miklos
miklos's Avatar
For 2 oil guages.......Do I just need a T? Oil pressure and oil temp?
