![]() [/B]i just got my rebuilt motor installed and running but i have one problem. the temp. gauge and tach dont work. the motor is out of a 97 and the cars a 91 so im thinking that could be the issue. if the temp. sensor comes out of the block just below the intake manifold like i think it does, then i know that it is hooked up. im not to concerned about the tach but i really dont want to test drive the car without the temp. gauge working. does anyone have some ideas on whats going on here.
ok ill check that but i used the same one from the 91 motor and it worked fine then. it seems almost as if it has nothing to do with the temp. sensor itself since the tach isnt working either. i know the ecu is getting the rpm reading because the tach on my safc 2 works. i know it didnt blow a fuse, checked that. can anyone confirm that the temp. gauge is located on the block right under the center of the intake manifold.
Got the temp. gauge and tach workin. i put the temp. gauge from the old motor in and it worked fine. the tach was just cause the needle was stickin to those stupid e-bay gauge faces that are now gone.
