Old 09-11-2006, 07:40 PM   #1
dktkd
dktkd is an unknown quantity at this point
Rear Brake Piston Boot popped out..
My rear brake piston boot unseated while I was
turning the piston back in.
What the best way to get them in without tearing them?
Can I remove the piston and just seat the boot back in.
Will brake fluid spill out if I take the piston out?
Thanks.
DK
dktkd is offline   Reply With Quote
Old 09-11-2006, 11:38 PM   #2
Jung918
Jung918's Avatar
Jung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfection
If you take off the piston, fluid will leak. I have never tried to put the cover on with the piston still in the caliper. What I usually do with the piston off is put the top part of the boot slighly on the piston and the bottom part in the caliper grove. Then I just slide it in.
Jung918 is offline   Reply With Quote
Old 09-12-2006, 11:56 AM   #3
dktkd
Update.
I'm such a newb.
I disconnected the brake hose, and emerg brake and then
took off the caliper. Pulled the piston out, slid off the piston boot.
Cleaned it up a bit. But a little break lube on the boot. Put the boot
at the base of the piston , leaving room to seat the bottom
of the boot to the piston housing. Then turned the back in.
Woo hoo.
But i realized that my bleede valve is seized.
Is there a way I can bleed the brake wihtout using the
bleeder valve.
Old 09-12-2006, 12:21 PM   #4
Jung918
Jung918's Avatar
No.
message length
Old 09-13-2006, 05:38 PM   #5
dktkd
Update.
After a combination of PB Blaster, light hammering and
heat cooling hammering x 3, I was able to get the bleeder
valce out.
The bolt head was barely holding on, on the
verge of rounding.
Off to get new bleeder valves and bleed my breaks.
Thanks for every ones help.
Old 09-13-2006, 08:03 PM   #6
dvdevo
dvdevo will become famous soon enoughdvdevo will become famous soon enoughdvdevo will become famous soon enoughdvdevo will become famous soon enough
good job on figuring out the stuff yourself
dvdevo is offline   Reply With Quote
Old 09-14-2006, 09:23 AM   #7
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
Feedback Score: 48 reviews
get some speedbleeders
Good to see a newb getting his hands dirty and figuring things out himself, props.
Old 09-14-2006, 09:38 AM   #8
dopeassjackson
dopeassjackson is a well-known jackass
one of my rear calipers on my s13 was all full of rust and seazed up, i was able to fit it with a wire brush and some carfeul disassembly. just make sure you lube every thing up before u get it back to gether. and no you cant bleed the brakes with out a bleeder. spray some PB blaster on it and if that dont work try a torch, replace it once you get it lose
dopeassjackson is offline   Reply With Quote
Old 09-14-2006, 10:14 AM   #9
Neejay
Neejay's Avatar
Neejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfection
+1 for speedbleeders. Super-easy life saver.
Neejay is offline   Reply With Quote
