Old 09-17-2006, 07:22 PM   #1
Id RaThEr DrIfT
Id RaThEr DrIfT's Avatar
Id RaThEr DrIfT is on a distinguished road
how to take off the valve cover off my sr.. and a smal lil problem
okay i wanna take off the walve cover/head to see what kinda cams my car has and to see what's broken cause just recently my car was leaking oil from the line to the turbo so i wasn't using my car, i decided to use my car yesterday without boosting, since i knew it had leaked a lot of oil but i had to pass up a bike to get off the freeway and ever since then my car CLACKS everytime i rev it/ give it gas and its comming from the head ... i already fixed the lines that were leaking and put oil in but now i wanna see what it might be. my dad said it might be a lifter or a rockerarm stopper what u do u guys think? and how to take off the valve cover?
i took off all the studs/bolts except one cause its just spins but doesnt come off but anyways the cover doesnt wanna come off. is there a specific tool or way? THANX and any help would be appreciated .........
"WhEn SoMeOnE yOu DoNt KnOw HaTeS yOu ThAtS wHeN yOu KnOw YoUr ThE bEsT"
Id RaThEr DrIfT is offline   Reply With Quote
Old 09-17-2006, 08:31 PM   #2
Gnnr
Gnnr's Avatar
Get and use the FSM from Zeroyon.com, was looking at removing the head today in FSM and it thoroughly details the process.
Gnnr is offline   Reply With Quote
Old 09-17-2006, 08:59 PM   #3
rim_bender
rim_bender is on the path to ruinrim_bender is on the path to ruinrim_bender is on the path to ruin
jsut remove all the bolts around the valve cover, remove the few hoses you see attatched to the valve cover, remove coil packs, and jsut take it off, its pretty eeasy, jsut take off what you see is attatched or holdign it down, there are no special tools for this
rim_bender is offline   Reply With Quote
Old 09-17-2006, 09:26 PM   #4
WilloW
WilloW's Avatar
WilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfection
Send a message via AIM to WilloW Send a message via Yahoo to WilloW
Just don't go and gorrila torque them valve cover bolts when you're putting it back together, otherwise you'll be snapping them.
WilloW is offline   Reply With Quote
Old 09-17-2006, 09:39 PM   #5
Id RaThEr DrIfT
well i took the bolts off and the hoses and it doesnt come off its like stuck onto the block .......... alos 1 of the screws doesnt wanna come out it spins but doesnt rise up.... so yeah but anyways the valve cover doesnt wanna come off
Old 09-17-2006, 10:50 PM   #6
S14DB
AFC #1
S14DB's Avatar
You break the seal? There is a light coat of RTV to hold the gasket on.
Old 09-17-2006, 11:00 PM   #7
Id RaThEr DrIfT
so how do i get threw that?
Old 09-18-2006, 01:44 AM   #8
Flybert
You have to get all the nuts off before you the take the valve cover. Get that last nut off and you can get the valve cover off.
BTW, the head is not the valve cover. The valve cover is bolted to the head and the head is bolted to the block.
Old 09-18-2006, 01:50 AM   #9
cotbu
cotbu's Avatar
Add pulling pressure to that nut, just a little, so it grabs on the next thread. Remember which bolt that nut went on. Clean the threads on both nut and bolt with tap and die, and a washer when you put it back on. Or get a replacement oem bolt and nut.
But, if you can't get the valve cover off you should have someone else do it.
Preferably, someone with a masters in ass-wiping.
Old 09-18-2006, 02:23 AM   #10
Id RaThEr DrIfT
okay thanx for the info guys .... but does anyone know what i could have broke or messed up to make that clacking noise comming from the head???
