Old 04-09-2006, 05:22 PM   #1
lcpljrm
lcpljrm's Avatar
lcpljrm is an unknown quantity at this point
High horespower n/a vq
i'm just looking to get opinions on the viability of building a high rpm high hp n/a vq. i was thinking along the lines of a vq35 block from a z, and the crank and rods from a vq30det. those crank and rods can be had from performance nissan for relatively cheap. then all you would need would be some custom pistons with the piston pin moved a few(7, i think) milimeters down in whatever compression ratio you wanted. then there are the cosworth heads and the nismo s2 cam blanks that you can will allow a duration of up to 312 degrees. my reasons for such an engine are that it is much lighter than the other nissan engines available for our cars. the mass is also closer to the center of the vehicle. and na power is just cool. anyway, i'm just looking for thoughts and opinions.
p.s. i'm talking about building this motor for a swap into an s-chassis
lcpljrm is offline   Reply With Quote
