Old 10-19-2006, 06:31 PM   #1
TurbLu
TurbLu is making his/her stupidity well-knownTurbLu is making his/her stupidity well-knownTurbLu is making his/her stupidity well-known
SR Wiring ??? - o2 Sensor cut, is this the plug?((pics))
Ok guys... Im at the last of my Sr swap wiring details. I need to extend my o2 sensor but its cut at the o2 sensor (about a foot away from it). Im pretty sure this plug (pictured below)is the plug. I dont have the end that plugs into it for the o2 sensor. Should I cut the plug off and use quick-disconnect connectors? Also which wire connects to which plug?
Red: (brown Im assuming)
Black: (black I'm assuming)
White: (white Im assuming)
Am I correct here? Or am I totally wrong and this isnt even my o2 sensor wiring? The pics are down on frsports wiring diagram so this is making it harder for me to figure out.
TurbLu is offline   Reply With Quote
Old 10-20-2006, 10:32 AM   #2
TurbLu
bump for help on this topic - could someone go outside and check for me...
Old 10-20-2006, 09:50 PM   #3
projectRDM
projectRDM's Avatar
What's outside?
Do you have a new O2 sensor? Because that would tell you right away, but I'm feeling nice. Yes, that's the O2 plug, engine harness side. And I don't know why you're extending it, if anything it needs to be shortened since it's about six inches too long. Unless you're one of those 'stuff it all behind the engine and make it look like shit' kind of guys.
Old 10-21-2006, 02:24 AM   #4
GSXRJJordan
GSXRJJordan's Avatar
Originally Posted by R240NA
What's outside?
lol took the words right out of my... well, wherever words come out on the forums.
No reason to lengthen, but yeah you've got the right wires, I'm not sure about the pinout though - I just remember it's counterintuitive.
Old 10-21-2006, 07:20 AM   #5
g6civcx
g6civcx's Avatar
I had to lengthen mine slightly, but I prefer to reroute the O2 sensor wires as far away from the heat source as possible. This is not necessary.
Search for my threads on O2 sensors. You will see the wire colours. All 3-wire heated narrowband O2 sensors are very similar. They consist of the signal wire in the middle, and non-polarity 12V (+) and (-) wires on the outside.
